Footswitch to switch between two speakers?
I've got a Laney LC30 combo and the stock speaker is very nice for cleans, but not so nice for the OD channel - I tried running the Laney through a cheapo 2 x 12" cab and the OD channel sounded a lot better, though the cleans weren't as nice, so I was wondering if there's a footswitch available that would enable me to switch between the two (both are 8 ohm loads) preferably without making any loud noises in the process.
new amp time. Hadn't thought of that. |
You could just pickup a DOD a/b pedal for about $30 bucks of if you are into wiring electronics, orders some parts and make your own for about the same price. An a/b box has got to be the easiest pedal one could make. I built one recently and it's puuuuurfect. Noiseless switching, metal case, DC jack, and LCDs all for $30 bucks. They also work in reverse say if you want to run two guitars into one amp and switch them when needed without having to put your amp in standby and unplug your guitars. hope this helps
"Thank you, good bye, and better luck next time" http://www.myspace.com/robertsred |
If your Laney has a solid state power section, switching speakers while power amp is on is a real no-no. Also, I would think that even the most passive of AB boxes will add resistance to the circuit, which doesn't matter much to a guitar signal, but may be death to a power-amp speaker relationship.
You better ask somebody smarter than me is all I'm sayin'
"Who's that singing? That can't be me, I don't sound like that." |
This has been asked before. My original answer was: In short no, no, no, more no. Think of this: With a swithch that a/b's between two speakers when you switch to one speaker (load) you leave speaker B (still connected to your output of your amp), but NOW you have an open circuit on the A speaker.In short, a no load situation. Open circuits and tube amps don't mix. Check your manual and I bet it says "Never operate this amplifier with no speaker connected" (assuming you have a tube amp of course.) As someone else said, "New amp time"!!!
Now having re-thought this, I conclude that you may be able to do this since the amp will "see" a load once you switch. Also assuming that both speakers are the same impedance. If not a whole new host of woolies grows from the mismatch. But that raises another problem in htat you may for an instant see a no load situation as you switch. A brief instant of no load. To a roaring amp that brief moment in time while actuating the switch is a lifetime to electrons. Don't do it, at least not on your dumble. |
oops forgot: Transistor amps are far more forgiving. I switch speakers a/b on my home stereo on the fly all the time.. Sorry for the double post.
Well I tested my 2 x 12" cab with a multimeter and it's defininitely 8 ohms amd my Laney is all valve, but the things you are saying about the brief period of no load when you're switching speakers etc, plus the increased possibility of accidentally disconnecting them are making me think it's probably not a good idea. I'll probably just have to try and find a replacement for the stock speaker that does good cleans and an OD that I like too.
I would really like to see an experiment conducted to test this theory...preferably using someone else's equipment.
#12
I wouldn't worry about a simple switch affecting your tone. |
#13
Ah right, ta for the info.
#14
The other thing you are going to have a problem with a loud POP when using a switch between speakers. Not a good idea in my opinion.
Live Clean and Play Dirty |
#15
#16
Another option is the Tonebone Cab-bone, which is an A/B switch designed to make sure that there is always a load on the head. If anything ever fails, then it falls back to connecting cab #1 to the head to ensure a load. Still, you have to make sure all the impedances match up. Yes, it's more expensive than a plain old A/B box, but then which is cheaper? Buying a Cab-bone, or replacing/repairing your head?
http://www.tonebone.com/tb-cabbone.htm |
#17
Thanks, that looks like exactly the thing I need, but the fact that they've included a feature like this:
And Cabbone is safe – switching is controlled by a timer IC that manages a ramped connection overlap. This ensures a constant load on the output, a major concern with tube amps. ...makes me wonder whether you really can do it safely with a simple passive switch, the only problem being that it costs $300, with which I could buy 2 or 3 decent quality speakers (or more if I managed to resell any ones I didn't like) ah well. |
#18
Put a Celestion in the Laney. Those HH speakers break up in a strange way, celestions always sounded better in my Laney setups. YMMV
#19
#20
#21
| New webpage explaining speaker impedances, etc. | gusfinley | Guitars and Basses | 11 | 12-04-2005 04:27 |
| ProCo Switch Witch for Studios with Multiple Monitors | heartsoffire | Free Ads for Music / Recording Equipment | 0 | 02-19-2005 10:29 |
| power to satellite speakers | nonothing | Newbies | 7 | 11-16-2003 23:17 |
| RMS power, Peak(music) POWER? | covana | Newbies | 3 | 12-04-2001 14:42 |
