help with mixer
hi i have a behringer pmx2000 powered mixer, and ive tried using it to record on my computer but it gives of a hum, and i was wondering if i got an unpowered mixer if this would fix my problem, i like putting each mic into a mixer then sending the final mix of whatever it is im recording (drums, guiar, bass) into my computer. if anyone could help i would greatly appriciate it.
i just sent the line out on the behringer where i would usually plug speakers into, into the computers line in, i tried the mic input to just incase
if it's a powered mixer like you say, make sure you are'nt running the mixer's power amp into the sound card. you'll blow the shit out of the sound card.
how do i not run the power amp into the computer?
that mixer has preamp outputs. i'm not sure if those are line level but i'm guessing that they are. try using the the left/mono and right preamp outputs to your sound card. how are you connecting? an adapter?
also, connect your mixer into the same power outlet that the computer is using to help prevent a ground loop. a ground loop will cause hum. just don't send any powered outputs to the sound card. |
you could use the tape out's too. try the tape out's vs. the preamp out's and see what sounds best.
yes i use a quarter inch to an eigth inch adapter.
whats the tape out, sorry im not very advanced in this area.
I'm looking at the PMH2000 (formerly the PMX2000 according to zzounds) online, and it looks like you have the option of preamp outputs (L/Mono, Right via 1/4" jacks). Or you can use the Tape/Line Output via stereo RCA jacks. I would say your best option would be to get a stereo mini to stereo RCA cable and connect the mixer via the RCA Tape/Line Output into the Line In on your sound card.
okay ill give that a try
#12
man that worked awesome thank you both so much for helping me ive posted my problem on just about every message board possible and nobody has helped but i thank you with all my heart, thank you so much. the tape out worked likea charm i havent tried the preamp yet but i will soon. thanks again
#13
i blew my sound card i plugged in a powered mixer 10 sec later it smelled like burning my cmputer shut down i turn it back up the left side didn work but hey u learn from mistakes
| PA vs Powered Mixer: Differences? | SKYflyer | Newbies | 5 | 08-07-2005 12:34 |
| Stereo out from mixer to Multitracker | paz8473 | Newbies | 3 | 05-29-2005 13:13 |
| Delta 44 vs. Windows Recording Mixer. God help me. | Shepherd | Digital Recording & Computers | 2 | 06-09-2003 07:39 |
| Help! How to route my mixer so I can monitor effects using my computer | kelitupu | Newbies | 3 | 05-10-2002 01:38 |
| my recording setup - NEEDS HELP | sykotic | Digital Recording & Computers | 12 | 10-06-2001 17:26 |
