Alesis DM5 question...
Just curious....if i wanted to use this rack system with a triggered kick on an acoustic set.....how can i output from it into my Presonus Firepod???as i dont see any outs for it....thanx alot really need help with this one
You're not looking hard enough. There are two sets of stereo outputs on the DM5 - one main and one aux. If you're looking at the back, they are on the right.
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music. __________________ "Do yourself a favour just shut up, read up then put up." --muttley600 |
yes.... i see those outputs....so what ur sayin is i run the stero aux land right into 2 channels of my firepod that thats it??? i was hoping there was a way of outputting each trigger channel seperatles but i guess not.
wise guy?? :S i was only asking a question dude
And I was only answering it. If my advice isn't helpful then don't take it.
If you know how to use MIDI, you can capture your music via the MIDI output as you play your drums using the triggers. Once you have your drum tracks recorded to a MIDI track, the possibilities are endless.
-Fishmed |
That's exactly what I do, works out well though sometimes I find it easier to use 1 out for snare, 1 for bass, 1 for toms and 1 for cymbals.
Kevin - www.icanquitsmoking.org The Small Business Workshop My Generic Crap The Murphy Cabinet Company Custom Hardwood Amplifier & Speaker Cabinets |
If you use MIDI like Fishmed suggests, you can record each part separately in MIDI, and then using MIDI sync you can record each drum voice to its own audio track through the firepod (4 voices at a time).
MIDI takes time to get yuour head round, but it's worth it. Orc |
if you ask me, a dm5 is only good for midi. the drum samples are'nt very good.
#12
could some1 give me a overview of how to hook up my DM5 to my FirePod so i can trigger bass samples from Drumkit From Hell for my kick drum?? and if possible an explanation on how to set it up in Cubase SX as well??
Thanx so much |
#13
You hook the midi out on the DM5 to the midi in on the firepod. In cubase record the midi input. Then assign that midi channel to DFH.
Exactly how to do that will be in the manuals of the DM5, Firepod, Cuabse and DFH. The concept is simple, but there are so many variations of device-interface-software that you really need to check the manuals of the stuff that you have.
#14
ok well that makes alot more sense now....but now how do i set my triggered kick drum as the right midi track on my alesis and or cubase if need be :S i dnt have the manual so thats y i ask
#15
How do you have $1000 worth of software and no manual?
The dm5 will just put out what ever note the kick is on what ever channel you tell it to (hit the 'midi' button and set the channel) You need to set cubase to record the midi input that the dm5 is plugged into and the channel that the dm5 is set to. Record it. Map the midi note that you recorded to the kick in DFH. press play.
#16
still dont know what u mean by mapping the midi note? lol sorry i dont know midi one bit
#17
You need to tell DFH what note is supposed to trigger a kick sound.
#18
Test. I'm just testing to see if I can post on this forum. It says I have to register at the top, but I already have. So I'm testing...testing...
Is this mic on? |
| Quick Alesis HD24 Software Question.... | newatthis | Newbies | 6 | 05-04-2005 16:04 |
| ALESIS HD24 Question... | newatthis | Alesis Forum | 8 | 05-02-2005 09:08 |
| Alesis HD24 Question ?????????????? | newatthis | Newbies | 3 | 04-28-2005 19:00 |
| Alesis D4/DM5 question | tubedude | Drums and Percussion | 1 | 12-09-2004 06:37 |
| Alesis DM5 vs. SR-16 | VooDu Valve | The Rack | 1 | 07-11-2004 08:37 |
