should i record vocals in mono or stereo?
i use adobe audition to record vocals with. should i put the setting on audio to mono or stereo when recording vocals? thanks
i record 2 vocal tracks at once - both in mono - pan them to taste, and add whatever effects to each track. thats just me though
thanks. does that make the vocal sound wider?
thanks alot man
vocals are a mono source...record them in mono.
mono=one one microphone=mono width or whatever is created by use of timebased effects (ie. reverbs or delays)
www.redlabaudio.com |
Vocals. Mono. Keep them in the center of the mix. Stereo reverb is good. Panning vocals, especially lead ones, no. Backgrounds, sometimes. Leads, no.
Unless you double-track them... but even then I'd use two mono channels, not one stereo...
One voice into one mic is mono, it doesn't matter how many tracks you send it to, it's mono. Don't waste hard drive space.
It is a waste of harddrive space to record a mono signal on a stereo track.
#12
#13
Sounds good to me to sing 2 mono separate takes, makes the vocals "wide" and loads of presence (IMO).
#14
I know I'll catch hell for it but I am going to be the descenting vote here and say record them in stereo. I think you should track everything in stereo when possible. This gives the listener more audible cues describing where the instruments and singer/singers are in the presence of the other musicians in the same actual space where the performance takes place.
The space utilization shouldn't be a consideration any longer because memory is cheap, real cheap. Tracking an instrument stereo using a d/i wouldn't make sense either because it won't add a thing. The all stereo tracking concept needs an acoustic environment that supports the music being played since this is the primary contributor to the sound of the air around the musicians and to how they react to the interaction of the sound of their instruments within the space they are performing. In your room, bass traps and your early reflection points take on an added significance in setting up your stereo field. Try setting the mics in a different location for the backup vocals(hint: in the back )Anyhow, Happy Monday! now flame away ![]() |
#15
If you record the vocals in stereo, the result will depend a lot on what stereo technique you use. If you put an x-y pair up close, the vocals will probably move around between left and right a lot as the singer slightly moves his/her head. If you put a spaced pair of omnis a little further back, small head movements should not be as noticable.
I don't record vocals in stereo, but if I did I would probably try mid-side. That way, you have a mic pointed right at the singer getting the sound you are used to hearing, and you can dial in some stereo width later if it works for you. |
#16
If you're using just one mic, set AA to track in mono. If you're using two mics, then track in stereo. G. |
#17
I would record vocals in mono as well. Like people said before, sending the main vocal track to a stereo aux track with delays or reverb will "widen" the image for you. Recording vocals in "stereo" seems a little excessive.
Also, I read up there that someone records everything in stereo. Are you in Def Leppard?
There is the theory of the Moebius, a twist in the fabric of space where time becomes a loop. |
#18
#19
#20
If you're having problems with the singer moving you have options. Why make the style of music a limiting factor? Most styles of music don't have a single singer but even for those that do would have an added option for the singer to use panning as you go without being stuck to a knob. ![]() |
#21
Again, it's a different story if one is recording stereo for a specific sonic purpose (e.g. to get the room, to get different nearfield timbres, etc.) But if one is recording a mono source with stereo miking mainly just to have a stereo track, that's what you gotta work with unless it sums ok, no good options. G. |
#22
#23
yea i was talking about setting up the software to mono or stereo like Southside Glen said not tracking the vocals in mono or stereo. so after reading this i guess it's best to record vocals in mono. i should record addlibs and overdubbs in mono too right?
#24
Now (and this may be getting off track) if you want to take a mono source, send it to a effects processor (say like a delay) and then return that to a stereo track (because the delay is stereo), that is a pretty normal thing to do. The input into the delay is mono (your 1 microphone), but output is in stereo (because the delay effect is stereo).
#25
| 'stereo' vs 'mono' | togapalmer | Mixing / Mastering | 5 | 02-16-2006 14:11 |
| DSD Primer | BigRay | Recording Techniques | 0 | 01-07-2006 10:39 |
| Stereo Vocals? | flourish | Digital Recording & Computers | 3 | 03-15-2005 18:08 |
| POD XT recording: Stereo -vs- Mono | jbe18 | Recording Techniques | 3 | 06-05-2004 11:39 |
| Mono or Stereo - advice wanted | darkwillow | Recording Techniques | 14 | 05-14-2003 13:11 |
