Drum machines in death metal?
I love playing heavy metal... especially death metal. The problem is I can't find a drummer that can get the job done. I'm considering using a (free standing) drum machine so I can start writing and recording. What I don't know is if these drum machines can be programmed to do blast beats and other complicated double bass/snare combinations. Has anyone used a drum machine for death metal? Give me some input!
I believe Agoraphobic Nosebleed uses a drum machine. If it isn't them, it's another band, but I know it's very possible. As long as you know what you want, you can make the drum machine as fast as you want; typically faster than human drummers. Like I said, though, knowing what you want the machine to play is going to be the hard part. That and staying with it tempo-wise.
"...I exalt you to examine yourselves; seek to discover where your true greatness lies. Seize your chance, rejoice in it, and let no power nor persuasion deter you from your task." |
There's a good program I recommend called Accoustica Beatcraft, check out for yourself how it sounds, this band plays blast beats and everything a Death Metaler is looking for: http://www.myspace.com/eoadisease
Abdullah |
If you send me a song that is completed with drum machine i might be able to replace that with real drums if i get round to learning it and recording it. it will be a challenge but i love playing death metal. as long at the blasts dont exceed 220 bpm i could probably do them.
Agoraphobic Nosebleed, Fuck...I'm Dead, and The Berzerker I believe all use drum machines. I'm positive about the first two. Mortician does as well, but they suck so I wouldn't worry about them.
Bottom line? Yes, it can be, and is, done. Oh yeah... www.myspace.com/fuckimdeadgrind http://Shop.relapse.com/dbmedia/audi..._Gravework.mp3 |
You can make most drum machines do anything you want. The trick is knowing how to tell the machine what you want. You will really have to know the difference between a 16th note and an 1/8 note triplet.
the only problem with bands like AN and berzerker who use drum machines on their albums...is that they still have to have a live drummer who can pull the shit off
Actually Death Metal is one of the few genres you can get away with using a drum machine. Drum machines can do some pretty extreme stuff, it just depends on your imagination and how real you want it to sound. Blast beats and crazy fills and stuff are the easy parts, getting them to sound human is the hard (impossible?) part.
I know its not technically the same as a drum machine, but I play a lot of death metal, and all my drums are programmed in midi. They sound pretty much like a kit. Its just a matter of making sure the velocities are a bit more human. Before I was doing that I was pasting wav files straigh into my sequencer. Like file for each hit. Took fucking ages but it came out sounding fairly real not as good midi tho. It just takes time and patience....
"Introduce a little anarchy. Upset the established order, and everything becomes chaos. I'm an agent of chaos. Oh, and you know the thing about chaos? It's fair..." |
I used to use a hardware drum machine and I had pretty good results.
Now I use midi drums (Drumkit From Hell Superior) which I think work much better and are far easier to use. (Not to mention sounding much more realistic). It can be done with a drum machine for sure.
Some of my music |
www.myspace.com/buryingthetrend this is Frooty Loop drums Acoustica isnt very good. Its too simple. Frooty Loops has more features that will enhance and make your drums come to life.
#12
Machines
"Do it right or don't fucking do it" ProTools LE 8 - MBox 2 iMac 24" 2.66Ghz, 4GB RAM, 1TB HD OS X 10.5.6 |
#13
Mix it up yourself with wav samples in Acid Pro 4.0.
As heard in myspace.com/sleepterror |
#14
#15
Samael has used drum machines from the beginning.
Torment, Violent Aggression, Systematic State of Oppression. The Heretics, All Swing From The trees, Cast To Hell, With Their Disease. DARKENED |
#16
I just bought BFD, and that program is bad fucking ass!!!!!! Real drums recorded wiht great equipment and put together in a sequencer. I haven't gotten into all of the really cool features, I'm just learning the basics (I've only had it 3 days now) and it's already blowing my mind.
Conditioned to self interest with emotion locked away.....if that's what they call normal then I'd rather be insane. |
| Metal (Death Metal) Guitars...Help!!! | Bloodsoaked | Newbies | 35 | 10-12-2006 14:00 |
| Valves... for death metal | killthepixelnow | Guitars and Basses | 9 | 06-07-2006 09:22 |
| "Killing You" hits #1 (Death Metal) | Bloodsoaked | Marketing Your Music / Publicity | 8 | 04-13-2006 17:59 |
| Midi drum stuff for the hard of thinking: | Alan McGuinness | Cakewalk / Sonar Forum | 3 | 12-12-2002 12:03 |
