Tascam TSR-8 problem help please?
Hi all,
I have got a Tascam TSR-8 set-up with a Seck 1282 mixing desk and I am having problems previewing the sound levels on the recorder. (The levels are fluctuating on the desk but not the recorder) Unfortuntunatly I do not have a manual for either one which makes my problem even harder to locate the source of the problem. I'm not 100% that I have connected the inputs and outputs properly but I have now hit a brick wall with it!!! Any suggestions guys? 8TrackLee |
I could be remembering it wrong as I haven't had one since mine to a little tumble down a flight of stairs about 4 years ago ![]()
True Creation Comes Of Nothingness -Winner Mix Contest 8- -Winner Mix Contest 11- |
That's right... the track buttons have to be engaged on the tracks you want to set levels or record on.
The "Track" outputs, 1-8 on the Seck connect to inputs 1-8 on the TSR-8. The outputs 1-8 on the TSR-8 connect to 8 of the tape inputs at the top of each channel on the Seck. Down by the fader on the board there are four buss assign buttons labeled 1-2, 3-4, 5-6, and 7-8. You must assign a channel to a pair of subgroups before any signal will flow out of the track outputs. For example if you want to send audio through channel-1 of the board to track-1 of the TSR-8; press down the button labeled 1-2, turn the pan control above the button fully to L (left) and bring up the channel fader and the group-1 fader. The manual for the TSR-8 is available from TASCAM Parts. Unfortunately there is no company support for the Seck, but you may be able to find a manual for sale online. ~Tim ![]()
«:: «::B::» «::E::» «::C::» «::K::» ::» "Where in the hell are the red M&M's?" ~My Lil' Sister, 1976 |
| Problem with my Tascam 414MKii | eternaltwilight | TASCAM User Forum | 1 | 12-16-2005 17:29 |
| Problem with my Tascam 414MKii | eternaltwilight | TASCAM User Forum | 0 | 12-16-2005 15:05 |
| Otari MX5050 to TASCAM M308B Problem | snipeguy | Analog Only | 5 | 03-09-2005 07:22 |
| Tascam 38 & 48 button problem? | Muckelroy | Analog Only | 4 | 01-20-2005 18:13 |
| Tascam Digital Mixer problem... | lost studios | TASCAM User Forum | 3 | 01-22-2003 11:21 |
