Old 08-05-2006
brooklyn23 brooklyn23 is offline
Junior Member
brooklyn23 has much to be proud ofbrooklyn23 has much to be proud ofbrooklyn23 has much to be proud ofbrooklyn23 has much to be proud ofbrooklyn23 has much to be proud ofbrooklyn23 has much to be proud ofbrooklyn23 has much to be proud ofbrooklyn23 has much to be proud ofbrooklyn23 has much to be proud of
I can't hear myself through my headphones?
I just set up my new firebox, and my at 4047 mic
i cant hear myself rapping though, when i put the headphones on.
How do i fix that?
Old 08-05-2006
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Look up 'direct monitoring' or 'zero latency monitoring' (or just monitoring) in the manual.
I don't have a firepod, so I can't give you specifics.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 08-05-2006
Junior Member
i read it, but still dont understand it
I hear the beat in my headphones, but no myself through the microphone
Old 08-05-2006
Freudian Slip's Avatar
Freudian Slip Freudian Slip is offline
Source Of Confusion
Freudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond repute
Fairview is right. There should be a direct monitor or monitor input feature in the software interface for the card. You only hear the beat because it is set up to only monitor play back right now. You need to change that. If you can not figure it out you may want to try calling customer assistance or visitng thier web site.
F.S.
"If Congress can do whatever in their discretion can be done by money, and will promote the General Welfare, the Government is no longer a limited one, possessing enumerated powers, but an indefinite one"
James Madison: the father of the Constitution
Old 08-06-2006
robbyrobmusik robbyrobmusik is offline
Junior Member
robbyrobmusik will become famous soon enoughrobbyrobmusik will become famous soon enough
is this common practice to hear your self in the headphones? I always thought you would hear just the beat in the headphone and you would record the vocals. I have been reading here alot of threads about "I cant hear myself through the cans!!"
Just wanted to know if this is the normal way or was my way of thinking wrong?
rob
Old 08-06-2006
Farview's Avatar
Yes, it is. That is what all the discussions about zero latency monitoring are all about.
Jay Walsh
Old 08-06-2006
Junior Member
oh i see.. yea i remember reading that on some headphone i was looking at.. I take it zero latency means hearing yourself in real time right? Like as soon as u speak u hear it?
Old 08-06-2006
Farview's Avatar
That is it. If you are trying to monitor yourself through the DAW, it takes time to get your voice into the daw and back out again. That is called latency, and it will drive you nuts.
Jay Walsh
Old 08-06-2006
Newbie dude Newbie dude is offline
Dedicated Member
Newbie dude has a reputation beyond reputeNewbie dude has a reputation beyond reputeNewbie dude has a reputation beyond reputeNewbie dude has a reputation beyond reputeNewbie dude has a reputation beyond reputeNewbie dude has a reputation beyond reputeNewbie dude has a reputation beyond reputeNewbie dude has a reputation beyond reputeNewbie dude has a reputation beyond reputeNewbie dude has a reputation beyond reputeNewbie dude has a reputation beyond repute
First of all, of ourse you want to hear yourself in the microphones. Otherwise you'll be all off pitch and stuff.
Secondly, brooklyn, check your digital firebox mixer[ if you don't know how, post back sayin so, i'll tell you how] and make sure the button under "Mix to Headphones" is pushed.
Oh, and make sure the gain on which ever preamp you're using is high enough.
Heads Up! Extreme Isolation Headphones Dot Other Equipment and Reviews 59 10-22-2005 10:35
Noise-Cancelling Headphones DboG Other Equipment and Reviews 2 10-01-2005 18:47
Headphones for mixing Mo-Kay Mixing / Mastering 81 05-31-2005 16:21
Need new headphones Fire Dome Other Equipment and Reviews 7 02-24-2005 15:37
Cant Hear the Mic.... naitmusic Digital Recording & Computers 4 05-13-2004 17:22
