Old 08-04-2006
Jillchaw Jillchaw is offline
Junior Member
Jillchaw is infamous around these partsJillchaw is infamous around these partsJillchaw is infamous around these partsJillchaw is infamous around these partsJillchaw is infamous around these partsJillchaw is infamous around these partsJillchaw is infamous around these partsJillchaw is infamous around these partsJillchaw is infamous around these partsJillchaw is infamous around these partsJillchaw is infamous around these parts
MORE Tascam 388 (lights)
One of the meter lights is out in my 388. How do i go about fixing it? Does the part have to be ordered from tascam? Thanks for any help.
Old 08-04-2006
jpmorris's Avatar
jpmorris jpmorris is offline
Tape Wolf
jpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond repute
Well since it's probably just the light bulb that's failed, you might be able to find a compatible part, but yeah, get one from Tascam or their distributors. When I replaced a bulb on my '32, they didn't have the proper fuse-type lights, I ended up with a wired one, although you can just wrap the leads around the terminals or something to make it work.
Probably the worst bit is going to be opening the machine up - I'm not sure how easy it is to access the meters internally.
Old 08-04-2006
Herm's Avatar
Herm Herm is offline
1K Silver Member
Herm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond repute
I would say unless you really really need that bulb dont start taking your rig apart to replace it. Its no picknick. You will have to pull atleast 2 cards out of your 388 and take 3 screws out of the meter frame to get them out.
They come out 4 at a time.
Then you will have to cut the tape on the meter and unsolder the bulb and then solder the new bulb in.
The problem with taking out the boards you will need to replace the bulbs is some of these are getting to the age that they dont want to come out real easy and can be a real problem to put back in with out damaging the pins they sit on and the connectors they push down on.
I have had one apart and would just live with it.
To replace a little light bulb can end up costing you the use of your rig for good.
If its working ok dont mess with it.
Old 08-04-2006
Junior Member
ok
OK thanks for the advice. I guess its not worth it at this point.
Old 11-18-2006
shedshrine's Avatar
shedshrine shedshrine is offline
just press record dammit
shedshrine has a reputation beyond reputeshedshrine has a reputation beyond reputeshedshrine has a reputation beyond reputeshedshrine has a reputation beyond reputeshedshrine has a reputation beyond reputeshedshrine has a reputation beyond reputeshedshrine has a reputation beyond reputeshedshrine has a reputation beyond reputeshedshrine has a reputation beyond reputeshedshrine has a reputation beyond reputeshedshrine has a reputation beyond repute
Just a thought. What about running a very short string of those tiny Christmas, er, holiday lights, clear or frosted, and attaching them behind the base of the vu meters . You could run them so there is a socket behind each vu, and put bulbs in as the original ones blow.
The backlit ones may look a little funky next to the meters that still have bulbs burning inside the vu box brightness-wise, but would make the previously dark ones easier to read. Just attach the leads to the power supply in some way, right?
Or it's just a firehazard. Nevermind..
Tascam 388 owners, Click Here
My new TASCAM 388 + LOTS of pictures!! cjacek Analog Only 86 08-19-2008 13:12
Tascam 388 Users? Joe Nathan TASCAM User Forum 2 02-26-2006 15:13
Just got a Tascam 388 for Free Carbona Analog Only 19 09-06-2005 15:28
FS/FT: Tascam 388, Han-D-Mag, ART Phantom II's, Hosa snake curtiswyant Free Ads for Music / Recording Equipment 0 04-04-2005 11:35
Quantex 499 on a Tascam 388 lofipower Analog Only 1 07-04-2004 17:52
