Old 08-01-2006
Brok_Homz's Avatar
Brok_Homz Brok_Homz is offline
Junior Member
Brok_Homz has a brilliant futureBrok_Homz has a brilliant futureBrok_Homz has a brilliant futureBrok_Homz has a brilliant futureBrok_Homz has a brilliant futureBrok_Homz has a brilliant futureBrok_Homz has a brilliant futureBrok_Homz has a brilliant futureBrok_Homz has a brilliant futureBrok_Homz has a brilliant futureBrok_Homz has a brilliant future
Bad headphone connections on my M Audio 410
Hello,
The soundcard I use for recording is a M AUDIO 410 firewire. There are two headphone outputs on this product. The bottom one works fine, but the top one has very sensitive connectivity problems with every single headphones that I plug into it. Im wondering, should I:
-try and fix it myself (Open it up and take a look)
-bring it into a local electronic store
-bring it into the store that I bought it from (about 200 miles away)
-or contact M AUDIO tech support
thanks for the time.
Old 08-01-2006
NYMorningstar NYMorningstar is offline
Recording Modus Operandi
NYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond repute
If it's under warranty then get let someone that's qualified do the work.
Old 08-01-2006
Brok_Homz's Avatar
Junior Member
yeah that makes sense... ill check that!
Old 08-01-2006
Nicole_Rose's Avatar
Nicole_Rose Nicole_Rose is offline
Great White North Girl
Nicole_Rose has a reputation beyond reputeNicole_Rose has a reputation beyond reputeNicole_Rose has a reputation beyond reputeNicole_Rose has a reputation beyond reputeNicole_Rose has a reputation beyond reputeNicole_Rose has a reputation beyond reputeNicole_Rose has a reputation beyond reputeNicole_Rose has a reputation beyond reputeNicole_Rose has a reputation beyond reputeNicole_Rose has a reputation beyond reputeNicole_Rose has a reputation beyond repute
and sometimes if it's under warranty they make sure that you have to send it back to them to fix it or the warranty is void, so check your warranty conditions.
If ignorance was water the world would drown.
How to use Waves X-Noise (noise reduction) properly? quietb03 Mixing / Mastering 3 07-27-2006 17:11
Manning 1 Questions about making a drum pad onlydude MIDI Mania 14 04-20-2005 16:35
Recording out of headphone jack? Good idea / Bad idea? rozsand Newbies 1 08-08-2004 17:23
dual soundcards with onboard audio: bad idea? Bergen Digital Recording & Computers 4 02-26-2004 19:21
PC DAW Digest TAE Digital Recording & Computers 0 11-25-2000 09:03
