Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 08-01-2006
legionserial's Avatar
legionserial legionserial is offline
Dead
legionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond repute
Meters
Ok so I'm little confused about a minor issue that I just want to clarify. On the cubase mixer there is options for meter input, meter post-fader, and meter post-panner. Now I have no problem understanding what that means at all, however...
When I am setting up to record, lets say I have the mixer set on meter input, and I'm sending my guitar in so that its averaging at about -12db on the meter. I dont add any effects to the input channel, and I leave the fader at zero, using my pre to alter the volume going in, or in some cases my amp.
Bearing this in mind, if I then set the meters to post-fader, there shouldn't be any diference in what it reading out? Is this the case?
I noticed the other night when tracking some bass, that what the input channel read, when set to input meter, seemed to be different to what it reads post fader, despite everything being set to 0 (with no EQ or effects)
Is this normal or do I have a problem?
Cheers
"Introduce a little anarchy. Upset the established order, and everything becomes chaos. I'm an agent of chaos.
Oh, and you know the thing about chaos? It's fair..."
Old 08-01-2006
Halion's Avatar
Halion Halion is offline
1K Silver Member
Halion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond repute
I suppose that is indeed what it should be. Perhaps the meters just act differently when used on the input. Maybe at input, the meters go up to 0db, while metering the faders would go up to +6db?
Old 08-01-2006
Dead
I just had a look on cubase to see if could be more precise as to what i was talking about. and it doesn't appear to be an issue now. I must have been doing something wrong before. Usually the best explaination for strange things....
Decibel Scales and Meters: Newbeeeee question sgpatel Newbies 8 01-12-2006 09:22
Decibel scale and meters sgpatel Mixing / Mastering 14 01-12-2006 01:20
Motu 896 meters vs. Cubase meters? affleckp Cubase User Forum 1 06-09-2005 12:18
fostex g-16 meters dead?? ROBOTQUALITYREC Analog Only 4 10-29-2003 21:47
level meters...are they acurate? Lomitus Cakewalk / Sonar Forum 16 05-16-2003 17:57
