newb question about effects
I have a Gk bass head and it has a built in patch bay for tuner out send and return, can someone explain send and return to me, especially on how and why its useful or not.
http://i42.photobucket.com/albums/e3...ic/banner2.gif |
in a simple guitar/amp configuration, there are only two places to patch effects like chorus, fuzz,delay,reverb,filter, tuner, whatever.
1. You can plug your guitar into the chorus pedal, and then patch the chorus pedal to the amp. Simple enough, right? 2. The send and return on your amp allow you to also patch FX or other devices into the mix. In it's simplest form, you plug your guitar into the amp input. You use a 1/4" patch cable from the send to the inout on your chorus pedal, and a cable from the out of the chorus pedal to the return on the amp. You have now added the same effect to your signal chain, but in a different place. The effect this has on your signal can depend on a lot of things usually centering on effects type. The effects loop on an amp is typically used for reverb/delay type effects. One thing to note is that the effects loop on your amp is inserted post-pre and pre-post. That means whatever you insert here is being fed by the pre-amp in your amplifier BEFORE it gets to the power amp section of your amp. This fact can also add wonderfull and crazy effects with different pedals, processors and channel and gain settings. FX loops are fun to play with, patch in different boxes and processors and start playing around. You can't cause any damage. Just make sure send goes to "in" and return comes from "out".
"Who's that singing? That can't be me, I don't sound like that." |
hey man thanks a ton for clearing it up for me, I had a feelign that's what it did, but yes, thank you!
Just to add something.... digital efx tend to work better through the loop while analog pedals work best between the guitar and amp. Especialy on solid state amps.
The more I learn, the more I realize how much I don't know. http://www.soundclick.com/sixfeetover |
| 388 effects return question? | warcloud3 | TASCAM User Forum | 2 | 03-02-2006 17:18 |
| Effects during monitoring...not the usual question | Myriad_Rocker | Recording Techniques | 5 | 01-06-2006 09:56 |
| Newb question... recording in stereo | HyperAXISZ2 | Recording Techniques | 4 | 12-09-2005 15:23 |
| yet, another effects question | lgsmith | Cool Edit Pro / Adobe Audition Forum | 2 | 02-12-2004 11:03 |
| Heres a question for you: ---> Plugin Effects or Hardware effects? | anppilot | The Rack | 11 | 07-22-2001 13:50 |
