Go Back   Home Recording > User Forums by Brand > Cool Edit Pro / Adobe Audition Forum
Reply    Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 07-31-2006
guitarfreak12's Avatar
guitarfreak12 guitarfreak12 is offline
Dedicated Member
guitarfreak12 is a splendid one to beholdguitarfreak12 is a splendid one to beholdguitarfreak12 is a splendid one to beholdguitarfreak12 is a splendid one to beholdguitarfreak12 is a splendid one to beholdguitarfreak12 is a splendid one to beholdguitarfreak12 is a splendid one to behold
monitoring
I was mutli-tracking this weekend and noticed that my main meter on the bottom is clipping even though the individual tracks are not. What's up with that, I set the monitoring to smart and external, and everything else. I ran with it, baecause as far as I could tell just as long as the individual channel wasn't clipping on the input, it was fine.
Omit Peas From the Menu
you Pot Bellied, Crazy, Solid Gold Dancer
Old 07-31-2006
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
(A) The *individual channels* are probably NOT clipping.
(B) When you add those channels together, you're going to clip.
(C) Take it as an omen - It's very likely that you're tracking way, Way, WAY too hot.
Channels shouldn't be "not clipping" -- They should be "not even close to being remotely worried about every possibly getting near clipping" -- 0dBVU as a reference - Not -0dBFS.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 07-31-2006
Dedicated Member
ok, thanks. That being said I wasn't really close to clipping at all on the tracks, isn't it better to record that way (as close as you can while avoiding clipping) so that you have a better SNR, and you can bring them down as much as you want in post?
Old 07-31-2006
dobro dobro is online now
Moderator
dobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond repute
Nope, not in digital.
Take a look at this thread; it might get you started on understanding why it's better *not* to record hot:
http://homerecording.com/bbs/showthread.php?t=202058
Old 07-31-2006
Dedicated Member
ok, wow, it's amazing what you don't ever hear. Or at least listen to. Now you said "0dBVU = around -18dBFS" rule of thumb. Now does that mean -18DBFS is what the reading is in the computer?
Old 07-31-2006
Dedicated Member
nevermind I dug around and found the answer. So should I read the main level indicator, or individual tracks? Which one should I take to -18dBFS?
Old 07-31-2006
Moderator
When you're recording, follow that -18 dB guideline for the individual tracks. That'll keep the levels where they ought to be.
When you're mixing, you don't have to be so fussy. The master volume can be set higher, as long as it isn't clipping.
Old 08-01-2006
Dedicated Member
ok, let me repeat you in a dummy fashioin to make sure I got it. The rule of thumb discussed is only for recording, it's ok to take everything up in post right?
Old 08-01-2006
I wouldn't move the master fader - Just as a matter of course.
You don't have to be *as* fussy, no. But in practice, you should be.
Everyone (almost) is going to use up all of their headroom in the mastering phase anyway - Using it up *ONCE* is one thing. Using it up over and over again is another.
Old 08-01-2006
Dedicated Member
ok, got it, thanks guys
US-122 - Direct Monitoring - I Need Help! KiFF BluEs TASCAM User Forum 13 05-16-2006 20:02
Help - monitoring chain involves my chin! guttadaj Recording Techniques 3 05-08-2004 00:00
NEWBIES using stereo sound cards Article on how to set up your monitoring. manning1 Newbies 10 01-08-2004 05:19
Monitoring equipment: some unconventional wisdom jeffree Other Equipment and Reviews 16 10-27-2003 18:57
Monitoring settings via delta soundcard frist44 Cubase User Forum 0 12-04-2001 16:43
