Old 07-29-2006
krhall's Avatar
krhall krhall is offline
Senior Member
krhall has a reputation beyond reputekrhall has a reputation beyond reputekrhall has a reputation beyond reputekrhall has a reputation beyond reputekrhall has a reputation beyond reputekrhall has a reputation beyond reputekrhall has a reputation beyond reputekrhall has a reputation beyond reputekrhall has a reputation beyond reputekrhall has a reputation beyond reputekrhall has a reputation beyond repute
Exclamation Urgent info needed on TEAC A-3300S Tape Recorder
Does anyone here havE A FULL SCHEMATIC DIAGRAM or SERVICE MANUAL for a TEAC A-3300S tape recorder.
I have found that the previous owner has bypassed what i assume to be the automatic stop sensor on the right trailer arm there are 6 wires that were joined together and one of these was causeing a 60 Volt shortout to the metal frame of the machine. I have now seperated these wires and that part is fixed. All i need to know now is what to do with these 6 wires or the part that should have been there but now isn't.
The only way i can identify what part or parts are missing to restore this machine.
Also where would i get hold of a new reel turntable and spindle assembly.
Keith
Old 07-29-2006
krhall's Avatar
Senior Member
Exclamation Teac A-3300S Reel To Reel Tape Recorder
Also if you want i can provide photographs of the part of the machine where i think the missing part was located.
I can see 2 empty screw holes next to the inside part of the trailer arm for the right hand reel.
I have seperated the 6 wires and now the AC input circuit is clean and direct without any shortouts. So electronicly it is now sound.
As for audio circuits, i have so far been unable to test them as i believe this amateur repair by the previous owner rendered playback inoperable (Playback didn't work - whenever i pressed the play button i could hear the relay "click" and that was it, no servo engageing and reel motors didn't spin up.)
Also the previous owner modified a computer 3 pin lead to fit into the TWO pin socket so i have dumped that cable because i dont trust it's safety.
So if anyone can help, here are the following parts i need
1. Replacement Reel turntable and locking spindle assembly
2. Possibly a replacement automatic stop sender unit.
3. Replacement Pinch roller
4. looking at the record and playback heads they do show signs of conciderable wear so may need replacing too.
5. 2 Pin power cord.
Keith
Old 07-29-2006
jpmorris's Avatar
jpmorris jpmorris is offline
Tape Wolf
jpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond repute
Keith
Can you give a picture of the mains socket? If it's the same design as the weird 2-pin thing that Revox use, you can get one on ebay. Many people have retrofitted their Revoxes to IEC sockets. I've been considering it myself..
The pinch roller can be got from Charles Hyde - www.chsinteractive.co.uk
Assuming you have it and it's just gone soft, you can send it to www.terrysrubberrollers.com and he can rebuild it for you - you might be able to get a local roller firm (typewriters, printers, conveyor systems need these) to do the job for you. If it's missing completely, you'll have to buy one from CHS.
Heads - You can buy these from CHS too - look under 'Tascam 34B'. I think they'll fit - TEAC heads seem to be fairly universal amongst their models, which is good. They are around £80 each, though.
You could ask Phi Magnetronics if they have any compatible heads I suppose.. http://www.phi-magnetronics.co.uk - or see if you can get them relapped. There are a few firms in the UK which do this, but I can't remember any names right now. Phi might do it also.
The reel table is going to be tricky. Try asking CHS, or failing that try to get a 22-4 or 34B reel table and hope it fits. CHS might know if they're compatible. Otherwise you'll have to either get a parts machine, or sell yours for parts.
Hope that helps..
Old 07-29-2006
krhall's Avatar
Senior Member
hi ok i am uploading the picture of the AC input socket with this post.
And thanks for the info
Other images are the damage parcel force did to the machine whenit was in transit to me (The damaged reel turntable)
The possible missing part next to the right reel trailer arm
and the 6 wires that were causing a 60 volt current to be passed through the metal frame of the machine which i seperated and put into a terminal block until i can find what they are meant for.
Keith
Old 07-29-2006
jpmorris's Avatar
Tape Wolf
Keith
Okay. I can't offer more advice on the reel table other than trying to get a TASCAM 388 or 32 table and make it fit. Ultimately this is going to depend on the diameter and how it's attached to the reel motor.
The mains lead is the same type that Revox use - if you put 'Revox' into ebay you'll see one ending in about 8 days. £6.50 or slightly more for Buy-it-now.
CHS do claim to have heads for the A3300SX. IIRC the record head is used for both record and playback.
29039M HEAD RECORD £66.74 (£78.42 incl. VAT) 7 - 14 Days
29048S HEAD ERASE £28.56 (£33.56 incl. VAT) 7 - 14 Days
http://www.chsinteractive.co.uk/shop...f=TEAC&cat=INT
..I can't help with the other things, though.
Old 07-29-2006
krhall's Avatar
Senior Member
ok no probs
but this machine has 3 heads 1 X erase 1 X record and 1 X playback
thanks for the info
Keith
Old 07-29-2006
jpmorris's Avatar
Tape Wolf
ok no probs
Keith
Yes, but I believe the R and P heads are the same type, i.e. you buy two record heads.
Old 07-29-2006
krhall's Avatar
Senior Member
ahh i see ok
Thanks
Keith
Old 07-31-2006
krhall's Avatar
Senior Member
Ok i think i found a reel table that might fit, but the depth of the base itself looks too big.
Can someone take a look at this listing and see if this may fit my machine. (On my machine if i remove the 3 screws arrounf the center spindle the reel table seperates from the reel motor shaft making it easier to change it over.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
^^^^ This is the link to the ebay listing
Also please look at my previous thread for the image of the reel table i uploaded.
And also i still need info on the missing automatic stop controller that is supposed to be attached on the inside of the right tension arm.
At the moment all that remains there are 6 blanked off wires, and i believe none of the transport functions will work correctly without it.
Keith
Teac X-1000R Reel to Reel recorder RawDepth Free Ads for Music / Recording Equipment 1 06-03-2005 17:01
tascam 16-track tape recorder, help needed!! bonnie billy Other Equipment and Reviews 1 06-05-2002 08:28
tascam 16-track tape recorder, help needed!! bonnie billy Analog Only 5 06-05-2002 04:28
tascam 16-track recorder, help needed!! bonnie billy TASCAM User Forum 0 06-04-2002 07:09
Urgent Advice With Analog Tape Copying Needed! janek Analog Only 5 02-26-2002 15:55
