gold plated XLR
hi, i got a behringer condenser mic it has a gold plated XLR output, they recommend that i use a gold plated XLR lead, whats the difference between a gold plated and an ordinary lead, and is it going to make much of a differene if i get one.
Gold is a good conductor. I doubt seriously that you'd hear any difference between any cable with decent XLRs and gold plated ones.
Mike |
Gold doesn't tarnish very easily, meaning less maintenance. No real sonic difference, per se.
Doesn't the use of diffrent metals promote corrosion? Maybe not at such a low power.
-jeffrey
Gold is pretty inert. It can react with aluminum, that's about it.
The only thing better than gold is unobtainium.
Actually, with today's fuel prices, it's become a very popular element. I wouldn't plug my LDC into it though. |
This is a big misconception that gold is good for audio. The only reason to use gold is because it doesn't corrode. The problem is that any time you have two metals running side by side, you have a change in capacitance. That's not really that noticable with one or two, but add a bunch of connecters up and you degrade the audio.
Audiophile producers and engineers really can hear it.
“Build a man a fire and he'll be warm for a day. Set him on fire and he'll be warm for the rest of his life." |
Electrolytic corrosion and simple oxidation would be the only reasons I could say that gold is better than other connections. Two dissimilar metals lend themselves more likely to develop corrosion due to valance electrons moving between the materials trying to make a battery for you and all the while wearing the connectors a bit but I'm willing to bet that you'd wear the cable out before the connectors go. But hey,...what are the connectors on your mic and/or mic pre-made of huh?
I'd say a high quality, rebuildable/repairable, well made, well assembled and tightly fitting connector would take priority of what the pins or sockets are coated with...that's just me. ![]()
She's not the boss of me
Fun facts: Electrical conducttivity in (10^6)/(m * Ohm) Silver: 63 Copper: 59.6 Gold: 45.2 Aluminum: 37.7 Calcium: 29.8 Tungsten: 18.9 Zinc: 16.6 Nickel: 14.3 Cadmium: 13.8 Iron: 9.93 Tin: 9.17 Lead: 4.81 Uranium: 3.8 Carbon: 0.061 (resistors) Silicon: .00000000000000012 (if I counted the zeroes correctly) Contacts are plated with gold because a small thickness of gold doesn't do much harm, and gold is basically not reactive. (According to Wikipedia, gold does react with chlorine, fluorine, aqua regia, cyanide and mercury, so don't go polishing it with bleach, toothpaste, or any of the other three things that are all WAY too nasty to have around your home....)
| Mogami Aes/ebu Digital Cable Gold Xlr 110 Ohm?? | wesley tanner | Microphones | 1 | 12-27-2004 04:08 |
| Source for Gold Plated Lipstick Pickups | Fusioninspace | Guitars and Basses | 0 | 07-28-2004 11:28 |
| Gold Plated Hardware Question | sondriven | Guitars and Basses | 2 | 06-03-2003 08:55 |
| gold or burst? | jimistone | Guitars and Basses | 18 | 12-07-2002 20:10 |
| LowZ, HiZ, XLR, 1/4"... | SN | Recording Techniques | 0 | 10-07-1999 11:21 |
