Go Back   Home Recording > User Forums by Brand > TASCAM User Forum
Reply    Audiofanzine Tascam Tascam News Tascam Medias Tascam Tests Tascam Articles Tascam User Reviews Tascam Classifieds Ads
Old 07-26-2006
topspin topspin is offline
Newbie
topspin is on a distinguished road
Tascam 414 Problem ????
Hi everyone. I just bought a 414 off Ebay and I'm not sure the stereo inputs are working properly. I know they are intended to be effect returns but I wanted to use them as additional inputs as I want to tape 5 musical instruments at the same time live. It seems to me the gain of the stereo inputs are not equal to the main 4 other mixer channels. The manual says I should be able to set the level of the "5-6" stereo channel or the "7-8" stereo channel to the 2 o'clock position and get a normal gain. I have max'd out the level onctrols on the 5-6 or the 7-8 stereo inputs and the main monitor mix tells me that the gain is still a good bit less than the main 4 mixer channels to where I may not be able to use the stereo inputs to monitor live plus record. Is this normal for these units? Or should the gain be equivalent to what I have in the 4 mixer channels?
thanks...JD
Old 07-26-2006
Nico2112's Avatar
Nico2112 Nico2112 is offline
Dedicated Member
Nico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond repute
I'm no expert on the matter, but when I tried the same thing with mine, I got the same results as you mention. I managed to make it by lowering the gain in the main 4 channels, and compensating through the master fader. It was an emergency while mixing a gig long time ago.
After that experience, I started using an additional mixer for those purposes.
I know my coment didn't help, sorry.
Cheers!
Old 07-27-2006
A Reel Person's Avatar
A Reel Person A Reel Person is offline
It's Too Funky in Here!!!
A Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond repute
Arrow Yo, hey!
I've not played with the 414mkII's inputs 5/6/7/8 to know for sure, but it sounds about right. Remember, they are just "straight" line level inputs, with level pots but no boost or preamp. To turn those 5/6/7/8 inputs up to "10" might be appropriate, depending on how "hot" your instrument output is.
Also, as Nico said above, you can adjust for proper levels by compensating & adjusting down the other 4 inputs, then using the Master fader to boost the overall level to what it should be. It's not something I've used to know from experience (on the 414),... but I've used them on the 424mkII and it's relatively the same.
Do what you need to, as far as adjusting levels, and you'll be fine. The Inputs 5/6/7/8 seem to be working fine, based on your description.
Beatles and other Classic Rock covers!! Yeah, Yeah, Yeah!!!
637 songs by 191 bands.
Old 07-28-2006
Newbie
HEY thanks so much, and yes that makes sense...there is no pre amp on the INPUTS!
I will take your guys suggestions to level the inputs...
tascam US 122 Recording Problem thegermnyc Analog Only 1 05-23-2005 18:18
Mackie into Tascam problem SouthSIDE Glen Recording Techniques 2 04-27-2005 19:35
Tascam 414 receives no power ssb7171 TASCAM User Forum 3 10-01-2003 17:23
Tascam 38 and 58 problem....... ausrock Analog Only 5 08-30-2003 00:58
Tascam 414 Mkii to Tascam 488 mkii Abbott TASCAM User Forum 2 03-21-2002 15:00
