Hello all
As you can probably see, i am new here. At my home studio i have the following machines Fostex Model 80 Reel to reel tape recorder Teac A-3300S Reel to reel tape recorder Aiwa Model AX-7500 Tuner Amplifier With my Fostex machine there may be a problem When i record to tracks 1 and 2, it outputs through tracks 5 and 6 (tracks 1 and 2 there is only input - no output) I dont know if this is due to misalignment or faulty heads. I have tested all tracks and all other tracks are fine (slight bleed through on other tracks - No dropouts or distortions) Any information or guidelines much apreciated. Many thanks Keith Last edited by krhall; 07-26-2006 at 10:19.. Reason: Fixing Spelling errors |
It sends the input signal to those tracks so that you can record without repatching I think.
1 shows up on 5, 2 on 6, 3 on 7, and 4 on 8. It will only record on the track that you record enable. |
The fostex goes in to this mode when you only feed it with a 1 or 2 channels.
It is so you can use just a 2 output mixer for all tracks of the machine. Try plugging a cord into all of the channel inputs and see what happens. |
hi thanks for your reply i tried all of the channels and i get both input and out put on tracks 3 to 8 but on tracks 1 and 2 i get input only no output.
Keith |
| FOSTEX model 250 HELP!!!!???? | Shane69 | Fostex Forum | 1 | 06-10-2007 00:23 |
| FOSTEX MODEL 450 -8-CHANNEL MIXER | blue suede | Fostex Forum | 2 | 10-01-2005 08:37 |
| fostex model 80 through a mixer | Henryy | Analog Only | 1 | 10-15-2004 05:38 |
| fostex model 80, manual/info/help me/anything | bluesboy87 | Analog Only | 0 | 09-20-2004 15:48 |
| Parts for Model 80 and X-15 | dii | Fostex Forum | 0 | 05-24-2001 13:47 |
