Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 07-26-2006
SheHadTheJack SheHadTheJack is offline
Junior Member
SheHadTheJack has a reputation beyond reputeSheHadTheJack has a reputation beyond reputeSheHadTheJack has a reputation beyond reputeSheHadTheJack has a reputation beyond reputeSheHadTheJack has a reputation beyond reputeSheHadTheJack has a reputation beyond reputeSheHadTheJack has a reputation beyond reputeSheHadTheJack has a reputation beyond reputeSheHadTheJack has a reputation beyond reputeSheHadTheJack has a reputation beyond reputeSheHadTheJack has a reputation beyond repute
Talking How do i use sm57 properly?
Hi
I cannot figure this out. When i record with my sm57 the level is really really low. I have never tried other 57, but to me this doesnt seem right.
My ADK Hamburg records really high and nice at the same level on my Lexicon Omega. Ofcouse i realize they cannot really be compared.
Anyway, the 57 seems somewhat useless to me, except maybe for recording amplified guitar - but i dont have a loudspeaker for my amp at the moment, so i cant check it out.
Since everybody speaks so highly about the 57, i guess im doing something wrong.
A little afraid to ask this questions, since im sure the answers will leave me stupified
/carsten
Old 07-26-2006
SRR's Avatar
SRR SRR is offline
BAKOVAB
Location: Everywhere a computer is plugged in and operating.
SRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond repute
Seems like some of these firewire/usb interface preamps are lacking gain for lower level mics. Goodness try pluggin a ribbon into that thing and it would go home crying. You can try just recording the highest gain setting you have and boosting in the mix, which isn't all that bad, unless there is a lot of noise that comes with the boosting. Another option is get an out board preamp that has more gain than what your unit has now. VTB-1 and DMP3 are good strating points, but there are better preamps for more money.
In a letter to his daughter, the MCP expressed unhappiness over the eagle as the symbol of America, he wanted the Tron guy.
Equipment
G.F.C.G. # 000 035
Old 07-26-2006
Junior Member
Turning up volume and boosting and stuff is not what im looking for. Too much noise. IŽll consider the vtb-1 (actually you can allready now find a topic from me about it in this forum).
Thanks for your comment
/Carsten
Old 07-27-2006
junplugged's Avatar
junplugged junplugged is offline
Busy Writing/Producing...
junplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond repute
Compare output of any dynamic and a condensor mic and you'll get the same results.
check the phase if you're using them at the same time, try closer mic'ing w/ the 57, or use it on louder sources, it's a good mic, used extensively, takes a beating.
Old 07-27-2006
chessrock's Avatar
chessrock chessrock is offline
Banned
chessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond repute
Turn the Goddang gain up.
Don't be a wuss.
Old 07-27-2006
hairylarry hairylarry is offline
Force of Nature
hairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond repute
impedance matching transformer
Hi,
I'm not sure if this will work with your rig but with my Fostex VF160 I have been using xlr to xlr mic cables and then going through low to high impedance matching transformers. The Fostex has eight 1/4 inch inputs but only two xlr inputs.
By using the matching transformers my mic run is low impedance but I get better gain at the deck. As a cautionary note these transformers can pick up noise from computer monitors or other electronics. Always listen carefully for noise before recording.
Many of the mics I use are dynamics similar to your SM57. The transformers cost $12 or so and they are also good for plugging low impedance xlr mics into high impedance PA amps with only 1/4 inch inputs.
Thanks,
Hairy Larry
Old 07-27-2006
PhilGood's Avatar
PhilGood PhilGood is offline
Juice Box Hero
PhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond repute
Dynamic mics have a lower output. That's one reason you can use them to mic loud sources (like drums) without having to use a -10db pad. (or -15 or -20) Switch on the pad on your Hamburg and you'll notice the levels are about the same.
“Build a man a fire and he'll be warm for a day. Set him on fire and he'll be warm for the rest of his life."
Step up from a SM57? mast and marque Microphones 18 07-29-2006 01:53
shure SM57 cable... BuXo16 Recording Techniques 3 07-07-2005 14:40
SM57 Slackmaster2K Microphones 29 01-08-2004 11:22
SM57 + preamp question (chessparov or anyone else ??) cjacek Microphones 16 03-20-2003 14:42
SHURE SM57 same as SM58 ?? gilwe Microphones 30 06-02-2002 19:40
