Go Back   Home Recording > User Forums by Brand > TASCAM User Forum
Reply    Audiofanzine Tascam Tascam News Tascam Medias Tascam Tests Tascam Articles Tascam User Reviews Tascam Classifieds Ads
Old 07-25-2006
Nico2112's Avatar
Nico2112 Nico2112 is offline
Dedicated Member
Nico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond repute
Making space in a DP-01
Ok guys. Let's see if any of you have tried this before.
I recorded a song and used all the 8 tracks. To get more space (in the same song) I usually transfer 7 or 6 tracks to the FAT partition, and then to the PC. Once I have those tracks in the PC, then I start recording new instruments in the song.
I was thinking in skipping the FAT partition to PC transfer, and just transfer the tracks to the FAT partition, giving each one of them it's name. Eg:
Drums001
Bass 002
GuitL 003...and so on.
And then, start recording right away new instruments. And after tracking them up, transfer to the FAT partition with a different name.
Has anybody done this before?
Will there be any problem?
Just thinking on how to speed up the process.
Cheers!
PD:Later on this week I'm going to experiment on doing this. I just wanted to know beforehand if you had done it.
Old 07-26-2006
Nicole_Rose's Avatar
Nicole_Rose Nicole_Rose is offline
Great White North Girl
Nicole_Rose has a reputation beyond reputeNicole_Rose has a reputation beyond reputeNicole_Rose has a reputation beyond reputeNicole_Rose has a reputation beyond reputeNicole_Rose has a reputation beyond reputeNicole_Rose has a reputation beyond reputeNicole_Rose has a reputation beyond reputeNicole_Rose has a reputation beyond reputeNicole_Rose has a reputation beyond reputeNicole_Rose has a reputation beyond reputeNicole_Rose has a reputation beyond repute
Drums001
Bass 002
Cheers!
i've done a lot of stuff like that. i've exported the files to the fat drive, and renamed them, but left them there to save time. then later i'd move them to the pc. here's the problem. once you get to a certain number of tracks on the fat drive it will crash. at least the last one i used did that. so i generally won't keep more than thirty tracks resident in the fat drive now.
you can also record 4 stereo tracks, export them, rename them, then mix down to the master stereo track. then you wipe the 8 tracks you have, and clone the master track to tracks 1 and 2 and now you have all the instruments to play to and three stereo tracks to record onto.
If ignorance was water the world would drown.
Old 07-26-2006
Nico2112's Avatar
Dedicated Member
Originally Posted by Nicole_Rose
...you can also record 4 stereo tracks, export them, rename them, then mix down to the master stereo track. then you wipe the 8 tracks you have, and clone the master track to tracks 1 and 2 and now you have all the instruments to play to and three stereo tracks to record onto.
Very good idea Nicole.
About storing tracks in the FAT partition, I won't leave them that long, so I guess I'm not going to have a problem.
Thanks for your post.
Cheers!
Old 07-27-2006
Bondo's Avatar
Bondo Bondo is offline
Senior Member
Bondo has a reputation beyond reputeBondo has a reputation beyond reputeBondo has a reputation beyond reputeBondo has a reputation beyond reputeBondo has a reputation beyond reputeBondo has a reputation beyond reputeBondo has a reputation beyond reputeBondo has a reputation beyond reputeBondo has a reputation beyond reputeBondo has a reputation beyond reputeBondo has a reputation beyond repute
When I was recording on one of these I would record basic rythm tracks, then mix that down to a scratch track. Then I would do a save as of the song and open the new one, keeping the scratch track and re-recording the other tracks. Then I would dump it all into my PC and mix and edit.
Old 07-30-2006
Dr.Bootleg's Avatar
Dr.Bootleg Dr.Bootleg is offline
Newbie
Dr.Bootleg has a reputation beyond reputeDr.Bootleg has a reputation beyond reputeDr.Bootleg has a reputation beyond reputeDr.Bootleg has a reputation beyond reputeDr.Bootleg has a reputation beyond reputeDr.Bootleg has a reputation beyond reputeDr.Bootleg has a reputation beyond reputeDr.Bootleg has a reputation beyond reputeDr.Bootleg has a reputation beyond reputeDr.Bootleg has a reputation beyond reputeDr.Bootleg has a reputation beyond repute
What I'm doing right now is putting about 8 to 9 tracks on the computer and then making a stereo mix of them. Then I'm gonna divide the stereo mix into two mono tracks, import them to the DP-01 and hard pan each of them. That way I can use the DP for final mixing. My computer is too old and crappy to make a final mix on.
But I like your ideas as well. That's what I like about this machine is that it gives you a lot of options as far as what you can do with it.
Old 07-31-2006
Bondo's Avatar
Senior Member
Witihn this, you may find it to be a good idea to master it on your computer. Even a free program like audacity should do this with pretty minimal requirements. Basically the DP01 doesnt seem to give a vry hot master and it can be hard to edit. What I would do is mx it then export to a program to edit and then to boost your final volume output. I have found this to be very effective.
Sound Proofing Office Space Digital Smith Studio Building & Display 12 04-23-2003 23:46
fill this space dr.colossus The Rack 10 04-15-2002 11:20
A technique for making space... tubedude Mixing / Mastering 2 12-19-2001 13:32
making internet collaboration work dobro Digital Recording & Computers 8 12-17-2001 11:41
Isolation Room into existing space. James HE Studio Building & Display 0 05-21-2001 16:40
