Tascam 424 mk111
I have discovered a problem with my Tascam 424 mk111.
I will record on Track 1 and then press stop and then disarm the track by putting it in safe mode. I will then arm track 2 and press play. (I can here my recorded stuff on track 1 because i have it switched to tape) But when I press record the old stuff cuts out and I record my new stuff on both tracks 1 and 2. I have no idea why...Cos only track 2 is armed to direct. Can anyone help? |
Are you monitoring using the Tape Cue?
When recording to track 2 set as "direct", you have to turn the panpot on the channel to the far right. It will then record only what is plugged into channel 2's input. Odd number tracks, the recording channel's panpot must be turned to the left, even number tracks, panpot to the right. Center the panpot and it will record a mix of the direct channel and anything else being monitored. |
To the OP, have you tried replicating the same scenario with different channels/tracks to see if it happens again? Not sure what that would prove, but would provide some more clues, maybe... |
tascam 424MKIII
I am curious about the choices of panning when recording. I know that the manual says you dont have to change tracks, just pan odd # tracks to the left, and even numbered to the right.
To avoid confusion, lets say I have recorded something on track 1, than I want to record on track 3, instead of just panning, I put track 1 into safe, and then I buss the source right into track 3 and pan at center. Is this o.k., or even if I go direct into track 3, should I pan track 3 all the way to the left, or pan in the center. I just find I am more apt not to make a mistake when I stay away from panning, and run my source right into the track itself and pan it in the center. Any thoughts? |
One thing I have mentioned here before, but I'll say again is I had an epiphany with my recorder (actually a 424mkii), when I came to realize the difference between "channels" and "tracks." When you are recording, all the stuff that you plug a source, and adjust with faders, pan knobs etc (basically everything on the left half of the machine), are channels - nothing more than any other mixer. However those sounds can be sent to track 1, 2, 3, or 4, depending on your intentions. Lets say you have 4 things plugged in channels 1-4. Anything panned L can go to track 1 and/or 3, and anything panned right can go to tracks 2 and/or 4. If you have something panned centered, if you have, for instance, track 1 in 'buss l' and track 2 in 'buss r' mode, it will go to both tracks. If you have the source track panned 75% right, 75 % of the sound will end up on track 2 and only 25% on track 1. Also, using this technique, rather than the direct mode, you could record up to 6 (or more? - not sure on the mkiii) sources just to tracks 1 and 2 in a stereo pair. You could put 6 mics on your drum kit, pan them to where you see fit, and record them as such on tracks 1 and 2 in full stereo. But, back to your original idea - here's what I'd do - pan channel 1 hard left. record your first instrument onto track 1 with 'buss l' selected. for your second instrument, rotate the pan knob hard right. Switch track 1 to 'safe' and track 2 to 'buss r'. Record 2nd instrument. To record the 3d instrument, rotate the pan knob back hard left, and switch track 2 to 'safe' and track 3 to 'buss l'...and so forth. This way, all you are doing is moving the safe-buss switches, and panning knob. if you are recording similar instruments (2 or 3 guitar tracks, or 2 or 3 vocals) you never need to unplug the mic from the channel 1 input, or reset the trim, or fader, or eq, or anything. This also works well, if you recorded a pretty good take, but want to see if you can do it a little better. Just switch to the next track (if they're not all full) and try a second take, without recording over the pretty good one. Wow, see what happens when you catch me right after lunch - I don't ever shut up.... |
| Tascam Portastudio 424 + Computer | Disposable | Newbies | 12 | 05-29-2008 13:39 |
| tascam 424 . need help/advice in mixing down. | greyJ | TASCAM User Forum | 3 | 01-19-2005 13:01 |
| New tascam time! Or maybe old! 424 mk III? 488? 238? etc... | osus | TASCAM User Forum | 10 | 11-09-2004 08:51 |
| connecting click to Tascam 424 | studiodrum | TASCAM User Forum | 1 | 10-24-2004 12:21 |
| condenser mics for Tascam 424 | studiodrum | TASCAM User Forum | 5 | 04-28-2004 09:31 |
