Can I use Cubase SL to edit a .wav file, or should I remix?
I’ve mixed down a song in Cubase SL to .wav format. I now realize I didn’t trim the ends enough (i.e. to reduce the length of the silence at the beginning and end of the song). Is it possible to trim a .wav file in cubase, or do I need to mix the song down again, or is this where I should export the .wav to cool edit/audition or something and trim it there before burning to an audio CD?
Similarly, I notice there is too much medium/low end in the mixed down song. Can I reduce the medium/low of the .wav file in Cubase or do I need to fix it before mixing down? Any advice would be greatly appreciated. Thank you all in advance, and all the best. Chang |
Yes, you can import the file in a new Cubase project and then, you can work with your wav file.
I think that if you want to reduce your mid/low, you can simply apply an EQ on the track where you imported the file! Ced |
| Can i do Regional edit in Cubase? | Aviel | Cubase User Forum | 0 | 04-28-2006 12:54 |
| Saving as a .WAV File | chesdanewf | Cakewalk / Sonar Forum | 7 | 04-03-2003 12:17 |
| Does cubase save a backup file for projects ? I erased it by mistake ... | gilwe | Cubase User Forum | 2 | 08-19-2002 18:03 |
| cubase to cool edit = problems | dobro | Cubase User Forum | 4 | 03-04-2000 14:11 |
| cubase to cool edit = worse sound? | dobro | MIDI Mania | 2 | 03-02-2000 20:59 |
