Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 07-20-2006
Jouni Jouni is offline
1K Silver Member
Jouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond repute
7-string or baritone?
This is what I've been thinkin'..
Allthough a bassist I compose a lot, now, Ive been doing songs to E and A 'cause my 6-string guitar..
All dudes around play metal from B from their 7-strings, that's why I got me a 5-string bass.
Recently saw baritone guitars that are made of longer scales and can be tuned to B or A without compromising intonation.
Playing with decent gear that thing should cast havoc?!!..
Since I've played bass the slightly fatter strings and longer neck shouldn't be a prob.. And something like a Les Paul baritone sure sounds like a bulldozer?
..allthough I'm a poor fellow and probably will have to get the Epiphone version..
So, a baritone would surely have something over a regular 7-string??
\m/ WAR OUT!! \m/
Old 07-20-2006
jndietz's Avatar
jndietz jndietz is offline
The Way It Moves
jndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond repute
I actually got an OLP MM5 baritone. Cheap, good guitar. I love it. Its very different and you may spend some time finding its place in your collection, at least I know I sure have. Its also an "affordable" baritone. Mine needs a pro setup pretty bad, though. I put on Dean Markely .14 - .65 strings, which is probably why it needs the setup (due to lighter strings than even a baritone). Baritones strings are a little more expensive (about ten dollars). But you can get a 3 pack of (sigh) Elixer baritone strings off eBay for $25.
Also, I suppose another advantage to the baritone is that you don't have to get used to the width and playability of a seven string.
But it will take some getting used to. You might (like me) have a hard time finding its place and its use in your collection.
I play lead guitar for a rock band called Indecision based out of Omaha, Nebraska. Check us out here
Old 07-20-2006
Purge's Avatar
Purge Purge is offline
acidrock sucks!!
Purge has a reputation beyond reputePurge has a reputation beyond reputePurge has a reputation beyond reputePurge has a reputation beyond reputePurge has a reputation beyond reputePurge has a reputation beyond reputePurge has a reputation beyond reputePurge has a reputation beyond reputePurge has a reputation beyond reputePurge has a reputation beyond reputePurge has a reputation beyond repute
I went with the 7 string first, although I plan on getting a baritone eventually. The main reason is that the 7 string gives you the best of all worlds--the option is there to play a "regular" guitar when you need it. For drop D stuff, you just slip into the 3rd fret on the B string and it works just fine. (Admittedly, it doesn't quite give that big open barking "woomph" that a low open D would, but I really do like the convenience of it all.)
The down side to the 7 is that you won't be able to fret barre chords with a B string root the way you would fret them on a normal guitar. You end up with some pretty strange augmented sounding silliness when you try this. On the upside, you can make some HUGE sounding chords when you find the right combinations.
Ibanez makes some good cheap guitars of both types, so give them a look if money's tight.
Bacon!!!
Old 07-20-2006
1K Silver Member
I only play bass in my bands, but since I've got a guitar allready I thought a baritone would "complete the set"- so to speak..
Yes, thanks i'll look at ibanez too.
Expensive strings I don't mind, not that poor.
Allready trying to imagine the "Ooomph" of those thicker strings!!
\m/ WAR OUT!! \m/
Old 07-20-2006
DeathKnell DeathKnell is offline
Junior Member
DeathKnell is on a distinguished road
depending on how adventurous you are with tunings,..
i've been looking at 7 strings lately myself. embaressingly i just had to google the baritone to find out what it was. I'd rather keep the range that the 7 string has, unless you're paranoid of being labelled a nu-metal kiddie or something
Old 07-20-2006
hiwatt357's Avatar
hiwatt357 hiwatt357 is offline
Senior Member
hiwatt357 has a reputation beyond reputehiwatt357 has a reputation beyond reputehiwatt357 has a reputation beyond reputehiwatt357 has a reputation beyond reputehiwatt357 has a reputation beyond reputehiwatt357 has a reputation beyond reputehiwatt357 has a reputation beyond reputehiwatt357 has a reputation beyond reputehiwatt357 has a reputation beyond reputehiwatt357 has a reputation beyond reputehiwatt357 has a reputation beyond repute
I have one of the Danelectro Baritones, and I dig it. Yeah, the 7 string guitars have the ability to go down pretty low, but as Purge stated, you can't do barre chords like you can on a baritone, and, to me, such sounds really cool in the right situation.
"I got Jackie Onassis in my pants..." - The Dictators
-Scott.
threefiveseven
Old 07-21-2006
faderbug faderbug is offline
faderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond repute
just get a 7-string baritone !
http://www.musiciansfriend.com/produ...1&src=3SOSWXXA
Old 07-21-2006
bileshake's Avatar
bileshake bileshake is offline
Senior Member
bileshake will become famous soon enough
If your a bass player and you sometimes play guitar than I'd get a baritone. The scale difference won't be much of a challenge if your already used to that sort of thing. My opinion of 7stringers originally was that a guitar player could play that low with out having a different scaled neck in his hands.
Gear:
G5 Dual 2G
Yorkville YSM1P's
Digi002 Rack Factory
Yamaha MD8
Zoom H4
Old 07-21-2006
hiwatt357's Avatar
Senior Member
Originally Posted by faderbug
At that point...shouldn't you just play bass?
-Scott.
threefiveseven
Old 07-21-2006
Grey Angel's Avatar
Grey Angel Grey Angel is offline
Angel of Shredding
Grey Angel has a reputation beyond reputeGrey Angel has a reputation beyond reputeGrey Angel has a reputation beyond reputeGrey Angel has a reputation beyond reputeGrey Angel has a reputation beyond reputeGrey Angel has a reputation beyond reputeGrey Angel has a reputation beyond reputeGrey Angel has a reputation beyond reputeGrey Angel has a reputation beyond reputeGrey Angel has a reputation beyond reputeGrey Angel has a reputation beyond repute
Sure, or you could just throw your hands in the air and get a Gibson double-neck
SnakeD-O-double G!: 5666
my musack!
For the love of God, SOMEONE help me tune my 12 string guitar! Mike Richardson Guitars and Basses 20 08-22-2007 11:09
Apples to apples, Taylors to Martins HapiCmpur Guitars and Basses 23 01-13-2006 19:32
7 string and baritone guitars cellardweller Guitars and Basses 27 02-21-2004 00:52
Guitar intonation mentil69 Guitars and Basses 30 03-30-2003 11:50
