Correctly mixing a female voice.
The band I have been working with has a female singer, and I'm just not used to recording sounds in that high of a range. She is a second soprano with a kind of husky tone. I want to keep that tone sounding true, but I've run into one obstacle after another.
What settings would you put the eq/compression, etc. on for such a voice to make sure that the sound stays intact? |
i would first make sure she has room in the mix and if the voice is that high make sure nothing in the same frequency range is interfering. if it's a vocal driven song maybe try mixing it around the vocals. otherwise, a little multiband compression in her frequency range might help if done properly but i have no idea if it would even be asking for it or not. let's hear it, hehe.
If you didn't record something that sounds like her, throwing gear and plugins at the resulting recording will never be the answer. This is a recording problem, not a mixing problem. Make sure she's working the mic correctly as she sings using proximity effect when needed. Make sure you're in the right room. Make sure you're using the right mic. etc. |
Compression technique shouldn't be any different because of gender, only EQ, and as always, there's no formula. You're still looking for competing frequencies within the mix, and carving a space for the vocal to sit. It may be the problem isn't so much how to treat her vocal as how to setup the rest of the mix to make room for it.
If possible you may want to try different microphones, until you find one that gives her the recorded sound you are looking for. That's usually preferable than to try and create the sound later.
Go figure
I had a similar experience back in the day. The singer was getting her "signature sound" from eating the mic. That's the sound she was looking for. I was trying to record her actual voice. In the end, we recorded her with a "57" and enough compression to keep the signal outa the red and more or less constant. To me it sounded freakish but she thought it was wonderful. Go figure.
chazba |
G. |
haaaaaaaaaaaaaaaaa....you fuckin' jokester, you.
I come from the taint of America, so don't bitch at me about your f*#@ing problems. You don't have to wake up everyday smelling like a mix of ass AND balls. |
$ .02
what glen said...and why not your gonna fix it in the mix right?
Ha, thanks guys.
I get the point. The tips were helpful though. I appreciate your responses. |
| Motif ES Rack voice mode question | Modern_Talking | Keyboards and Sound Modules | 5 | 05-11-2006 06:39 |
| A cheap mic for a female alto voice? | Mongoo | Microphones | 3 | 11-25-2005 17:12 |
| Question about HipHop/Rap Mixing | SwurVe | Mixing / Mastering | 54 | 08-02-2005 11:22 |
| Question about HipHop Mixing | SwurVe | Mixing / Mastering | 0 | 07-29-2005 22:13 |
