Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 07-19-2006
timboZ's Avatar
timboZ timboZ is offline
Band-Aid®
timboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond repute
Remove wrap from drumkit.
I am getting a Tama Rockstar kit and the wrap is in bad shape.
Can I remove the wrap and refinish the wood?
What is the best way to remove the wrap.
WARNING:
THIS POST DOESN'T CONTAIN ANYTHING HELPFUL
http://www.myspace.com/veritasrs
__________________________________________________________________________________________________
Old 07-19-2006
mikeh mikeh is offline
2.5K Gold Member
mikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond repute
Normally if a drum has wrap, it would suggest the woood was too flawed to be stained. So even if you get the wrap off and sand the wood, you may not have something that will look good.
If you do try to take the wrap off, be very, very carefull!!! The glue can tear out hunks of wood when you pull off the wrap.
Careful use of a heat gun (or a hair dryer) and tools such as a putty knife, etc. will be required.
If you get the wrap off and decide the wood can't be stained, you can always buy new warp!!
Old 07-19-2006
travelin travis travelin travis is offline
Banned
travelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond repute
You could probably paint the shells but it would be alot of work.
Old 07-19-2006
ermghoti ermghoti is offline
1K Silver Member
ermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond repute
This was my reflexive answer, but then I thought: the heat could warp or delaminate the shell. Maybe better not to mess with it, or try a solvent to loosen the glue?
Old 07-19-2006
Russtopher Russtopher is offline
Senior Member
Russtopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond repute
I've used the hair dryer method on a lot of kits, and as long as you go SLOOOOOOOOOOW you'll be ok.
BUT - be prepared for a LOT of sanding, glue removal, etc. I tried to re-finish a few kits this way, and the other posters are right - the outer layer of wood you expose is NOT worth the effort. Many shells will not stain the same color, have bad grain, and may even have spots of missing wood. The kits I stained I ended up painting/polycoating, and re-finishing in wrap.
My '62 Ludwig kit I removed the old wrap, and applied a White Satin Flame that I got from George's Drum Shop, along with email advice from George that was very helpful. If it's a lower-quality kit, spend the $150 or so and get a killer wrap.
Old 07-20-2006
Elton Bear Elton Bear is offline
Unregistered Abuser
Elton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond repute
I already said this in another thread, BUT here's my step-by-step guide:
1) Buy a Pearl Export with wrap
2) Wait
3) The wrap will fall off on its own eventually
Old 07-20-2006
timboZ's Avatar
Band-Aid®
I did find this video.
http://jamminsam.com/drum_wrap_video.htm
They make it look sooooooo EZ..........
The kit should arrive today. If it is not in to bad of shape I just may keep it as is.
Or just wrap it with some pink fur fabric like this
http://www.interiormall.com/images/c...n-Pink-Bla.jpg
WARNING:
Old 07-20-2006
BentRabbit's Avatar
BentRabbit BentRabbit is offline
Drumb & Drumber
BentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond repute
2) Wait
If you don't hear what the mix is telling you, you shouldn't be working on it in the first place. - John Scrip, Massive Mastering
Myspace Page
Old 07-20-2006
rweiss's Avatar
rweiss rweiss is offline
Dedicated Member
rweiss is a jewel in the roughrweiss is a jewel in the roughrweiss is a jewel in the rough
I had an older premier set, used the hair dryer/heat gun method to melt the glue around the seams. Get the wrap off using this method, then use paint thinner to remove the excess glue around the shells. My shells were mahogany, and I stained them yellow. They ended up looking great.
boomtap
Old 07-21-2006
Nico2112's Avatar
Nico2112 Nico2112 is offline
Dedicated Member
Nico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond repute
I would go with the Jamminsam material. It's precut and applies easily (according to the video). Also, many finishes to choose from.
Too bad they don't ship to El Salvador.
That's what I would do.
Cheers!
Old 07-21-2006
SMX_Dizzy SMX_Dizzy is offline
Paranoid, but no Android
SMX_Dizzy has a reputation beyond reputeSMX_Dizzy has a reputation beyond reputeSMX_Dizzy has a reputation beyond reputeSMX_Dizzy has a reputation beyond reputeSMX_Dizzy has a reputation beyond reputeSMX_Dizzy has a reputation beyond reputeSMX_Dizzy has a reputation beyond reputeSMX_Dizzy has a reputation beyond reputeSMX_Dizzy has a reputation beyond reputeSMX_Dizzy has a reputation beyond reputeSMX_Dizzy has a reputation beyond repute
There might be a thread with pictures and instructions on the Pearl Forum...I'll look.
Advantage of quad wrap cables? appleyardrules Microphones 7 07-18-2006 13:06
Drumkit from Hell - Installation from Hell Middleman Cakewalk / Sonar Forum 32 06-16-2006 09:43
<-Buying an Electronic Drumkit. Suggestions PLEASE! $1500 Range. dreamache Drums and Percussion 0 12-14-2005 20:41
How can i remove cracks..? drpfeffer Digital Recording & Computers 8 10-26-2005 22:40
