how to use my m-audio audio buddy and my mesa for Direct input
so i have an m-audio audio buddy and i just figured out that it not only is a preamp (which is what i have been using it for) but it also is a direct box, it has in two instrument ins and two xlr ins and two outputs. But what i am not sure is how to take my mesa single rec and put it in to the inputs can you help?
thanks |
any ideas on how i can record my mesa direct?
If you try to record your mesa d/i and don't have a load like an attenuator or speakers you'll kill the amp. Trust me, I know, I learned this lesson the very hard way. You CANNOT record a tube amp direct in unless you have something to soak up the power.
G Gunn does your Mesa have a lineout? I know the Mark series do. Warning: the line out by itself sounds like yuck without either a cab sim or a an amp sim (pc) and judicious eq.applied. If you have line out run it into your di or into a line level in on your A buddy (if it has one) My Mark 3 has a varioble line out which could be run into the pre-amp in on ABuddy, but you could run into serious gain issues eg. the line level may be too hot for pre input. YMMV. If you can go line out - di- mic pre you should be alright with proper gain staging. But like I said, the tone will definitely need some shaping as you do not have the power amp/speaker/air/mic guitar interaction. YOu could run line out to Abuddy chain and mic the gtr cab and record onto seperate input channel on A buddy. I have done both with similar equipment and had mixed results. It has been a while. This will not work for silent recording as the amp will output to cab when line out is in use. Unless you have a Mark iv which I believe has a silent recording option. Check back tommorrow as we are closing shop here soon.
Share you thougts and results. |
all i have is a slace out and the fx out...so i didnt think so but my di box has xlr's and blanced inputs, so this is not possible unless i have a preamp....?
What is a "slace" out? If you mean that you have a line out use it to input the di balanced 1/4" input (its is ok if your line out is unbalanced it should still work on th balanced input of di) then out of di via xlr into mic input on audio buddy. By the way I posted to the wrong guy yesterday my bad. Long day.
Yes my bad....all i have is a slave out and effects loop on the mesa single rec 50watt and my audio buddy has two balanced /unablanced and two xlr's in the rear...still possible to record direct?
#12
