Old 07-18-2006
superbeatballer's Avatar
superbeatballer superbeatballer is offline
Force of Nature
superbeatballer has a reputation beyond reputesuperbeatballer has a reputation beyond reputesuperbeatballer has a reputation beyond reputesuperbeatballer has a reputation beyond reputesuperbeatballer has a reputation beyond reputesuperbeatballer has a reputation beyond reputesuperbeatballer has a reputation beyond reputesuperbeatballer has a reputation beyond reputesuperbeatballer has a reputation beyond reputesuperbeatballer has a reputation beyond reputesuperbeatballer has a reputation beyond repute
Ampex transformers
I have an old Ampex am-10 solid state mixer with the original unbalanced output transformers.
What I'm wondering is if these will balance the output.
If so, I will buy it now.
Thanks in advance!
Originally Posted by superbeatballer View Post
Thanks for the cool new signature.
Old 07-18-2006
Dr ZEE's Avatar
Dr ZEE Dr ZEE is offline
Anti-Pro Circles Insider
Dr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond repute
what are "original unbalanced output transformers" ?
I'm attaching a cut from the diagram (output section) of am-10:
Dr ZEE
MZE | ZDL | DZW
Old 07-18-2006
Force of Nature
Maybe my wording was unclear.
A "reliable" source told me that the outputs are unbalanced. I believed this because the output amp and unbalanced line inputs(channels 4 and 6) share the same module. He went on to tell me that the accessory plug-in "transformers" on the rear panel that I have currently are actually jumpers. I guess your red circle is telling me otherwise.
Here's an easy one: What's the purpose of those bridging transformers in the context of the am-10?
Here's another: What's a line termination switch in the context of channels 4 and 6?
I don't think this post is any more clear than my prior one. Sorry!
Old 07-18-2006
Dr ZEE's Avatar
outputs are balanced. 4 and 6 are line inputs are unbalanced if dummy plug(or call it jumpers, which what it is) are installed (plugged) (which you may have there) or can be balanced with optional input transformers. Which exactly transformers? I have no clue, you need to find part ##, if there's such thing as manual for am-10, I would imagin all the info there. All I could find was these docs.
Balanced or unbalanced (with or without transformer) the line input signal off slider of the channel 4(or 6) "goes" to preamp card (pin #4) where it sums with signal of the channel 3(or 5) after mic preamp/mic gain slider) and then "goes" to the mix amp (A or B, outputs of which are balanced with output transformers inside the "red circle" )
I have no clue about termination switches and terminators.
Dr ZEE
MZE | ZDL | DZW
Old 07-22-2006
Force of Nature
Very Helpful. Thanks Zee!
ADK AP-1 Preamp with 5 transformers Dot Free Ads for Music / Recording Equipment 0 04-20-2006 18:21
Patchbay... With Transformers!?!? Derrick111 The Rack 7 12-15-2004 15:37
Reporting threads to the moderator . . . chessrock Microphones 19 03-05-2004 12:14
"Sticky Shed" with Ampex tapes Peter Maydew Analog Only 2 07-30-2002 04:37
Ampex 456 or 499 which is best? marksmith Analog Only 0 06-08-2002 07:47
