Go Back   Home Recording > User Forums by Brand > TASCAM User Forum
Reply    Audiofanzine Tascam Tascam News Tascam Medias Tascam Tests Tascam Articles Tascam User Reviews Tascam Classifieds Ads
Old 07-17-2006
TelePaul's Avatar
TelePaul TelePaul is offline
J to the R O C
TelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond repute
Pops/drop outs
just bought a cheap stereo micro-mixer: four inputs, left/right out which i tried running thru my tascam us 122. I'm using Cubase, so i tried recording each input to its own mono track. Every few seconds my sound is interrupted by a drop out or pop. Any idea as to why? It happened when I recorded both as a single stereo track too.
Originally Posted by Gummblefish
Went out yesterday all day long and spent 125 quid on a bender (not literally a bender )
Old 07-17-2006
Track Rat's Avatar
Total Gear Slut
It could be a lot of different things. My first guess would be a driver issue. Another guess would be clocking problem (like either mis matched sampling rate or wrong device set as clock master).
Mike
Old 07-17-2006
TelePaul's Avatar
J to the R O C
Im using a 16 bit ASIO driver...thats okay right? Yeah i guess its something to do with the buffer rate...would taking down the latency help? How would i check the sampling rate versus clock?
Old 07-17-2006
Track Rat's Avatar
Total Gear Slut
Look at the settings of your soundcard. If the bit depth and sampling rate is adjustable, that's the first place to look to see what it's set at. And then your recording software. Its settings have to match that of the soundcard. And if the card has a digtal input as well as an analog, depending on what you're inputting, all of the above has to told who's the boss.
Mike
Old 07-17-2006
TelePaul's Avatar
J to the R O C
Right........
Old 07-18-2006
auralmirage auralmirage is offline
Newbie
auralmirage has a brilliant futureauralmirage has a brilliant futureauralmirage has a brilliant futureauralmirage has a brilliant futureauralmirage has a brilliant futureauralmirage has a brilliant futureauralmirage has a brilliant futureauralmirage has a brilliant futureauralmirage has a brilliant futureauralmirage has a brilliant futureauralmirage has a brilliant future
I switched back to tape because I was having problems with audio dropping out at low levels on Cubase. Is this what's happening to you? If so, it's all driver/soundcard related. I thought it might have been mic/mixer problems, but recording to tape doesn't yeild the same drop outs. Seems the audio driver has problems with very low sound levels. Hope this helps. I'd suggest an external sound card made with recording in mind.
Converting Channel Inserts to Direct Outs? Chief Pronto Recording Techniques 31 06-12-2006 15:13
Monitor outs - A question of quality bubbleboy Newbies 3 09-30-2004 07:34
Routing the Ins & Outs properly cincy_kid Digital Recording & Computers 10 07-14-2004 06:52
outs, and ins..confused martinepiphone Newbies 1 11-01-2003 01:06
Monitor outs? RideTheCrash Newbies 3 06-26-2003 12:04
