Go Back   Home Recording > General Discussions > DJ & Hip Hop Production
Reply    Audiofanzine Dj Dj News Dj Medias Dj Tests Dj Articles Dj User Reviews Dj Classifieds Ads
Old 07-15-2006
tone_aot's Avatar
tone_aot tone_aot is offline
1K Silver Member
tone_aot has a reputation beyond reputetone_aot has a reputation beyond reputetone_aot has a reputation beyond reputetone_aot has a reputation beyond reputetone_aot has a reputation beyond reputetone_aot has a reputation beyond reputetone_aot has a reputation beyond reputetone_aot has a reputation beyond reputetone_aot has a reputation beyond reputetone_aot has a reputation beyond reputetone_aot has a reputation beyond repute
Synchronizing Software
Does anyone know how to synchronize Acid Pro and FL Studio? I usually make the whole beat in FL, then pull the wave file into Acid. I wanna be able to record vocals/etc. in Acid while just hearing playback in FL so i can change things on the fly. This way, when i mix, i'll have total control over every sound and parameter in FL without having to literally pull individual tracks into Acid and i can listen to the vocals and change the music at the same time. Help?
Old 07-15-2006
DesertEase DesertEase is offline
Notorious
DesertEase has a reputation beyond reputeDesertEase has a reputation beyond reputeDesertEase has a reputation beyond reputeDesertEase has a reputation beyond reputeDesertEase has a reputation beyond reputeDesertEase has a reputation beyond reputeDesertEase has a reputation beyond reputeDesertEase has a reputation beyond reputeDesertEase has a reputation beyond reputeDesertEase has a reputation beyond reputeDesertEase has a reputation beyond repute
FL Studio can function as a ReWire host for installed ReWire devices. The host functionality is implemented via the ReWired plugin. Each instance of the plugin lets you host one ReWire device (to use multiple devices, simply add multiple instances of the plugin to your project). I have flstudio6 XXl i'm not sure what version you have so check at the top where it says channels/ add one/ and look for Rewired.
Old 07-16-2006
tone_aot's Avatar
1K Silver Member
I don't have rewired. How do you get it?
Old 07-16-2006
tone_aot's Avatar
1K Silver Member
I heard of using some program called midi yoke to sync programs. Imma check that out unless i can get rewire some kind of way.
Old 07-16-2006
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
rewire is built into the software, you cant buy it. It should set it self up automatically when you start the two programs. Start the one you want as master first and the then the other one.
Yoke probably wont help since it will only allow you route midi and having two sound programs running independantly will definitely cause problems.
I really dont see why you dont settle on one package that does everything you need. Going back and forth between DAW software is a ridiculous way of working, Acid should be able to do everything and more than fruitly loops
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 07-16-2006
Notorious
Flstudio is the best sequencing software out therejust for the fact that it has more effects generators and bundled plug ins than any other software that is actually high quality, wut sold me on it was it's really easy user interface for 350.00 you really can't go wrong ( take for granted pretty much all of the standard synth sounds are crap but it's nuttin effects can't take care of) ( unlike laffy taffy) haha yo tone did u buy your fl online or in a box at the store? cuz if u did it online u just gotta sign on to myflstudio.com and u can upgrade to the newest versions of fl when they come out
Old 07-16-2006
tone_aot's Avatar
1K Silver Member
Hey altitude, if you can tell me one "package" that has all the features of acid and Fl and also has something similar to the beatmapper in acid(in as i can sequence the whole project on time with a grid system) i'll buy it!! Your comment tells me you must have not used fruity loops much. FL does alot of things acid can't do. Heck, Acid does crap FL can't do. These are two different types of programs so i think it would make plenty of sense if i could sync them together.
Old 07-16-2006
cubase
tracktion
logic
sonar
Live!
Digital Performer
Protools
take your pick. All of those will do what FL does and a lot more
I used 6 for a couple of weeks (they had it at the studio i was working at) and completely hated it. The whole boxed in structure of the sequencer is annoying and the workflow was awkward at best. No real external equipment support, plus the very poor recording setup coupled with almost no routing options makes severely limited.
Old 07-16-2006
tone_aot's Avatar
1K Silver Member
Oh yea! I agree that FL does suck at recording!!! I tried that when i got my asio card. I was all excited about it but after i tried it, i was like, dang. That's horrible. But, it works for what i use it for. Thinkin about gettin reason.
Do you really buy that expensive recording software? Fantastic_Mad Digital Recording & Computers 1815 14 Hours Ago 18:09
cubase educational? Daniull Cubase User Forum 8 10-28-2002 12:03
