Question about TASCAM FW-1082
Hi,
I am going to buy the TASCAM FW 1082, becasue I don't have the money to buy the M-Audio Project Mix. I need to record a band live with 8 tracks that will be recorded in my computer through the firewire as 8 independent sound tracks in the Cubase SW that comes with the system. I have read in several places that I need to have a bigger 6-pin Firewire card in my computer in order to do so. I can't understand that point because I thought the 4 pin small connector was exactly the same and had the same bandwitdth. Do you know if I can use my 4-pin computer FW port or do I need to add a FW board cost to my budget? I have a single 4-pin firewire port in my computer. Thanks very much Arturo |
When the FW-1082 was reviewed in SOS (here) the reviewer tried it out on his laptop (using the 4 pin connector ) and it worked fine.
I don't know if you'd run into problems long term though, the bottom line is Tascam advises against it so it's a risk. If you have a PCI slot going spare PCI firewire cards are really cheap these days. When I bought my 1082 I got an Adaptec fireconnect for about $20 off ebay (my comp wasn't firewire capable). It's worked flawlessly. They say that cards with a TI chipset are best for use with the Tascam. The Tascam forums are a bit slow but there's a lot of good info there: http://tascamforums.com/index.php?showforum=57
"Just give the great unwashed a pair of oversized breasts and a happy ending, and they'll 'oink' for more every time." C. M. Burns http://www.shuttleworths.co.uk/micloop.gif |
I've got the FW-1884 and I've always used the 4-pin thats on my laptop and never had a problem. my understanding of the 6 pin is that the last 2 pins carry power so that you can connect devices without needed an external power source (like USB).
btw, i've used several different laptops over the years, currently I have a Dell Inspiron E1705 with dual 2ghz processor, 2GB of RAM and 80gb HD. |
| question about tascam m312b mixer | puttinitonwax | Analog Only | 15 | 02-26-2006 10:51 |
| Tascam 1082 WANTED!!! | ODEKK | Free Ads for Music / Recording Equipment | 0 | 12-15-2005 18:09 |
| Newbie Tascam 424mkiii Channel/Track Question... | sad_analogist | Newbies | 3 | 11-22-2005 21:23 |
| Quick question on my new Tascam 414 mII | Siy | Other Equipment and Reviews | 3 | 11-19-2005 10:29 |
| tascam us-122 mic pre question | ismael | Digital Recording & Computers | 1 | 09-15-2005 22:39 |
