Need help Tascam424MK3 / manual wrong
I need to know where the "monitor select line out" switch should be when recording.
The manual says it should be in "L - R" when recording, and then a few pages later it says to select "mono" when recording. I assume this means you are either recording in stereo via " L - R", or mono if in "mono" position. I also assume we should record in "mono" Help!!!!! ![]() |
Controls whether the LINE OUT stereo mix will be output to the monitor mix in stereo (L-R), in mono (MONO) or not at all (OFF).
... The main use of this switch would be when you're overdubbing, and/or using any channel in the hard-panned (L or R) position,... in which case switching to MONO centers the hard-panned signal to the center. It's basically a listening convenience to hear your hard-panned input signals panned to center. You don't necessarily want to listen in the phones to the TAPE CUE mix (which is mono), and your live-input channel all the way in one ear or another. Hard-panning is part of a technique to route and direct the input signals to individual tracks, but depending on how many inputs and tracks you're using simultaneously,... hard panning isn't always necessary, and the PAN control may often be left in the center position. A lot of the intent of the MONITOR/LINE OUT switch is a convenience item to streamline the recording/overdubbing process,... as far as hearing your overdub input signal in both ears instead of one. That's what the MONITOR/LINE OUT switch is aimed toward. ![]()
a.k.a. Davemania! Beatles and other Classic Rock covers!! Yeah, Yeah, Yeah!!! 637 songs by 191 bands.
And bear in mind that the setting has no effect upon the recording signal itself. If you're recording to one track, it's mono; two tracks can be in stereo. Even if you turn it to the off position, the recording will be unaffected. Like recording to your VCR with the tv off.
The Cue and Monitor mix do not affect the Main-buss mix, which feeds signal to the tracks.
| Missing manual in SX3? | ColdAsh | Cubase User Forum | 4 | 08-02-2005 10:32 |
| Yamaha PSR330 - Need a manual | mikeh | Keyboards and Sound Modules | 4 | 07-21-2005 16:05 |
| Help 1010LT Installation what am I doing wrong? | Pier Calacino | Digital Recording & Computers | 8 | 05-06-2005 15:42 |
| 488 MK II Manual | DerekB | TASCAM User Forum | 5 | 04-19-2005 16:24 |
| Aaarrrhhhggg. European Manual. | tombuur | Cakewalk / Sonar Forum | 25 | 10-15-2004 15:31 |
