does it do THAT much difference?
quick question. Im satisfied with the tubes in my sebatron vmp4000e, im just curious as to how much difference in clarity, warmth, "feeling", a tube swap can do. I know the unit has 4 12AT7 tubes, but im not exactly sure what brand they are...or how high quality they are...im sure they are just fine. However, this http://www.tubedepot.com/cr-12at7.html has kind of gotten my attention. If i tried a tube swap with something like that, would there really be much of a sonic difference?..is it even worth it? Also..would at 12ax7 tube fit in the seb?
how old are the tubes?? youd be suprised how well a tube change can make the amp sound that much better |
I've had the same tubes in my Fender amp for years now and they're still fine. It's not so much 'time' that takes the toll on tubes, but rather use...
Jacob
Upmixed Productions |
yea, my amp sounded fine this morning. i imagine its a little pricey to replace them all. however, does anybody have any info on the orginal question?
because every time i try and email them, it rejects me as spam or something...i always get the yahoo mailer daemon or whatever....but this isnt about my sebatron, this is about preamps in general.
Maybe you can go the other way before you blow $150 bucks on tubes.....
Buy the really cheap ones and see if it makes it sound that much WORSE. Then you'll know if tubes make a whole heckuva lotta difference.....
Just think how good you could play if you were sober! My Little Corner Of The World SC's MySpace |
ok, now that im home..the sebatron is stocked with ecc81's buy JJ. maybe ill just upgrade brands to mullard...ive heard they produce a great sound. does anyone see any objections to this?..and do the crynovalves sound as good as the cost is high?
#12
Fortunately, 12AT7 tubes are pretty cheap compared to, say, 12AX7 tubes, except for the Tele's and Gold Lions. |
#13
#14
12AX7 - 100 mu 5571 - 70 mu (yes, this tube is in the same family) 12AT7 - 60 mu 12AY7 - 45 mu 12 AV7 - 41 mu 12AU7 - 19 mu The higher the mu, the higher the gain of the tube. Remember, not all preamps and mics that are designed to use a particular tube from this family can use the others. Most can. |
#15
I wouldn't be inclined to replace the 12at7s with 12ax7s. Although they physically fit and would work, the unit wasn't designed to operate with the higher gain tubes. And good 12ax7s are quite expensive compared to 12at7s. Most preamp tubes really have a pretty long life. We are talking years as opposed to months. If your Sebatron had come with Sovteks or cheap Chinese tubes, I'd say go ahead and change them out for better tubes (I have a VMP-2 that I changed out from Sovteks to GT Mullard copies and real Mullards). With the JJs you have in now, which are better than Sovteks, I'm less certain that any difference will necessarily be worth the price unless you get a real good deal on really good tubes. In my case, it did make a difference in the smoothness of the sound. Reduced the gain a little bit too, which wasn't a problem.
Yeah I'm an attorney, but everyone needs a day job. |
| ANybody here think High End Pre's are Overrated? | MadMax | The Rack | 174 | 09-13-2006 17:34 |
| Can you REALLY tell the difference between Mic pre-amps? | Robertt8 | Microphones | 28 | 07-06-2003 12:58 |
| Omni Studio/Audio Buddy any difference? | ella | Microphones | 0 | 03-11-2003 12:02 |
| Difference between track and channel? | braveheart | Newbies | 8 | 12-07-2002 05:38 |
