Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 12-23-2000
LSA100X LSA100X is offline
Newbie
LSA100X is on a distinguished road
When I play the patches of my JV1080 in multi timbral mode, they sound very different than when I play them in patch mode. How can I get the normal patch sound in multi mode? Any suggestions?m Any input would be appreciated. Thanx.......
Old 12-23-2000
rjt's Avatar
rjt rjt is offline
Force of Nature
rjt has a reputation beyond reputerjt has a reputation beyond reputerjt has a reputation beyond reputerjt has a reputation beyond reputerjt has a reputation beyond reputerjt has a reputation beyond reputerjt has a reputation beyond reputerjt has a reputation beyond reputerjt has a reputation beyond reputerjt has a reputation beyond reputerjt has a reputation beyond repute
One suggestion is that they all may be routed thought the multieffects of the multi instead of their individual patch effects. Each individual patch is programmed with reverb, chorus and insert effects. Those effects have to be stretched when all 16 parts are using them. You may have to record the voices individually, switching to the patch effects for each patch as you record this part. Let us know if that is not the problem.
Old 12-24-2000
dannymix dannymix is offline
Junior Member
dannymix is on a distinguished road
Its all to do with the effects section so I you go to the effects section (PERFORMANCE EFX TYPE) and select in the (Sorce PERFORMANCE) channel 1-16. Thats say you have a realy good sound on ch 1 but sounds better in the patch mode by selecting ch 1 as above it will copy the efx that was originaly with ch 1 sound that was in patch mode.
The only real pain is that you have this effect over all 16
channels. What I do is convert my MIDI track into audio in cubase and apply effects to it there you can get much better sounds this way.
The day there is a keyboard synth that has 128 poly and 32 parts with 5 efx to each channel I will and many others will be over joyed! till then good luck.
Dannymix
Danny
Old 12-26-2000
anppilot's Avatar
anppilot anppilot is offline
Never Act Like U Know All
anppilot has a reputation beyond reputeanppilot has a reputation beyond reputeanppilot has a reputation beyond reputeanppilot has a reputation beyond reputeanppilot has a reputation beyond reputeanppilot has a reputation beyond reputeanppilot has a reputation beyond reputeanppilot has a reputation beyond reputeanppilot has a reputation beyond reputeanppilot has a reputation beyond reputeanppilot has a reputation beyond repute
To cut out all the B/S, this is what I do. I use Cubase. Ok? So, I know its a little cumbersome, but, I record each track at a time as a sequence, then convert it straight to an audio track with the effect. But I only do that for patches that are programed with effects that I like. The ones that arent that big of a deal, I'll record them in Performance mode, then use Cubase for the effects.
Later,
Mike
