Old 07-11-2006
bigwillz24's Avatar
bigwillz24 bigwillz24 is offline
One Turd at a Time...
bigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond repute
Default Protools...
OK I started a new gig tracking at a small studio in town. They use protools I'm not that familiar with the program so the little changes tend to bother me.
I was wondering if there was a way I could make a new session template that will default everything on the system to the original settings and keep that on a cd with me so I can get started quicker during the sessions.
Old 07-11-2006
Micter's Avatar
Micter Micter is offline
No Title
Micter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond repute
Ya, you just set up a "template". Open a session, set everything up, save as whatever file name you want to call it, then iopen that session for each song and "save as" the name of the song.
Live Clean and Play Dirty
Old 07-11-2006
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
what do you mean by defaulting everything? If you mean a template like Micter is talking about:
create your file the way you want it
save it
close PT
Navigate to the session file and make it a Read Only File (Windows it's Properties-->Read only...probably under Get Info on Mac, I think they call it Static)
Now you can do this two ways, open this template up each time and when you select save it will ask you to name the file...OR...do what I do and create your new blank session and do File-->Import Session Data
Press Ctrl+A to select all the tracks in that session and click Import.
All the tracks will then be brought into PT.
This way you can have a different sample rate, file format or bit depth whenever you want, but can give you standard plugins/tracks that you use a lot.
If you're talking about defaulting just the I/O setup, you can create the I/O the way you want and then Export the settings as a file...then just load it up everytime you come in.
If you mean the way windows and stuff are setup, there really isn't a way to do that...if other people use the system and change things, they'll be changed each time you open a new session.
This will help clear out your peripherals if you want: http://protoolsforum.com/DigiPrefs.html
www.redlabaudio.com
Old 07-11-2006
bigwillz24's Avatar
Originally Posted by bennychico11
..snip...
Yeah that was what I was talking about. That link will come in handy though thanks.
Old 07-11-2006
DrJones's Avatar
DrJones DrJones is offline
Senior Member
DrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond repute
Create a template. Now how ever many songs you want to track you will "SAVE SESSION COPY IN". Name the session and check the boxes at the bottom of that window that apply to your session ie. create fade foder, plugin folder, ect. Save the session I whatever drive you choose, Click "SAVE". Repete for next session. You template will stay a template. If you do not SAVE SESSION COPY IN and check the applied boxes @ the bottom of that window, your files will default scattered all over the place. That is somthing I hated about the software untill I found this out. Try it and you'll understand.
MY Studio Pics Here http://myspace.com/piperstudio
* "You can only polish a turd so shiny" *
HELP! ProTools (digidesign) vs. ProTools M Powered (m-audio) vschiano2008 Digital Recording & Computers 3 11-17-2005 23:41
I want to upgrade to Protools Le Digi002 from..... anppilot1 Recording Techniques 23 08-12-2005 13:12
Yamaha AW16G + Mbox + protools = ? washingtonbc Digital Recording & Computers 4 06-14-2005 18:26
ProTools Free/Mac crisis mastrose Recording Techniques 2 05-05-2004 14:41
Default on the road with Rode Microphones Glawfindle Microphones 4 05-25-2003 17:21
