question about the vtb1
what does the function "reverse polarity" mean and do??
thats th eonly thing i really dont know/understand about the preamp that and.... on the back it has the 200 and 50 mic impendence to choose form. please explain that too. thanks |
reverse polarity... I'm under the impression that it when you have two microphones pointed at each other the sound will be recorded quite garbled because the sound vibrations mess with each other. By having one of the mics on reverse polarity, it changes the spectrum (or something) that the microphone picks up so that you can get a good sound. For instance... When I record drums, I will have one mic on the inside of the bass drum, and on on the outside by the place that the kick meets the drum (to get the click sound). Since both mics are pointed at each other, I would have one with reverse polarity. If this isn't the right answer, hopefully someone else can help you out.
In regards to mic impedance, this might be a good place to start, or just do a search through the mic forum here (check out Harvey Gerst's stuff, it's usually on top day after day in the mic forum, and extremely informative), or do a google search.
As far as reverse polarity, also known as phase reverse, when you have two mics recording at the same time they may, for some reason or another, start to cancel out certain frequencies. The source you record may sound "tinny" (you would know it if you heard it.).. That's because of all the frequencies that are being "cancelled out" by the other mic. If you hit the reverse polarity (or phase reverse) switch, it will clear all that up. I'm not by any means an expert, but it happens to the best of us along that lovely experimental road. Either one of these questions are probably better answered by google or Harvey, so try a search as well. I am only a lowly HR amateur... ![]() |
Used to be really helpful when recording drums with multiple mics. For example; If you close mic the snare and you have overhead mics, the sound from the snare will arrive at the OH's a little later than the snare mic hears it. Your recorded waveforms will be out of phase and the resulting snare sound will be thin. You reverse the phase on the snare mic-or the OH's- and your fat snare sound is back. This only works if you have the capability to monitor your sources. Or you could try a test recording, listen, adjust and then rerecord once you have your sources "phase aligned".
This is kind of old school advice now that we have waveform editing capability in our DAW's, but that's what the phase button is for. I don't even think about phase reversal on my pre's anymore. |
thanks a lot guys.
i know you guys are right about the polarity because when i recorded with 2 mxl 990's at the same time it was horirble and tiny and just nto right now im gona try and use the reverse polarity feature, also when im doing double bass too. thanks guys. helped me a lot. |
Another useful application of the polarity reverse is if you record your guitar amp using two mic's, one in the front at the speaker grille and one in the rear. This gives great results with open-back amps like the Fender Deluxe Reverb, for instance. But you have to flip the phase on one of them since the "push" phase of the front will be the "pull" phase of the back with relation to the speaker movement, and vice versa.
does it matter which mike has the polarity device on?? i onyl have 1 pre amp. so which mic would i put it on? |
So, in short, if one mic is cancelling the other out, and you reverse the phase on either one, your phase cancellation problem goes away. Good luck! ![]()
dross |
wow, is there any way i can flip the phase on my mics? I am using the firepod, and recording live drums and intruments, and i might be afraid i have this problem. I dont see any polarity switches anywhere, so is there another way to fix this?
Presonus Firepod (x2) Presonus Faderport Cubase Studio 4 Sennheiser E604 (x4) AKG D112 Sm57 Sennheiser e906 AKG Perception 200 Mesa Boogie Duel Rectifier Peavey 5150 Yamaha Stage Custom Yamaha HS80 Monitors Yamaha Subkick |
#12
I got a problem with my VTB1 as well... it seems like when I turn the nob to the tube pre instead of the solid state, my vocals get weird, real distorted and just messed up. I dunno if my compressor has annything to do with it or not, but I am confused about ti.
#13
#14
#15
cool. That's good to know Scrubby...
#16
#17
any specific reason why you dont???? i would think it would be better since it has a tube to add sound/flavor to the vox i've yet to expeiriement in detail with this preamp when it comes to vox so im still veyr sketchy about it. i wish i could sing... would amke things a lto easier lol |
#18
#19
Thanks scubby, i am using cubase le, hopefully i can find that phase reverse. What would i use it on anyhow. Like reverse one of my drum overheads? You think this will greatly help the sound? I am miking up my whole drum kit, anything else i should reverse? The guitar amps and bass are miked with one amp so i dont think thats gonna be a problem. Sometimes i do record "live" with 2 guitar players, bass and drums. Will switching the phase help this at all since all the mics are not far from eachother?
#20
#21
| Review – Studio Projects VTB1 mic pre | Dot | The Rack | 68 | 07-21-2007 21:29 |
| question about mixer | matt's bedroom | Newbies | 3 | 05-04-2006 05:24 |
| First Post: Ultimate Question!!! | HyperSpace | Recording Techniques | 19 | 04-25-2005 08:29 |
| Delta 1010 output question? | henry_mullis | Digital Recording & Computers | 1 | 12-28-2002 11:12 |
| stupid question about compression | deathofamind | Mixing / Mastering | 10 | 12-13-2002 21:10 |
