parametric eq question
i need a parametric eq for my studio, and i only want to spend from like $100-$200
but the only one i can even find that even parametric is the pre sonus 3 band EQ3B. it's $100 flat, and the next cheapest parametric eq i found was $800 on sweetwater.com for a parametric eq is thta my only option? and is it a good option?? any opinions on this eq from what i heard pre snous is a noisy brand |
Look for a used Rane PE-15 (or better yet, a Rane PE-17). Tese can often be found on eBay for about $100, maybe a bit more.
thanks. ill look it up now |
PAIA Electronics has a kit you can build for $100. mono, 4 band, all sweepable, and it's noiseless..... I use it on my bass tracks....
Just think how good you could play if you were sober! My Little Corner Of The World SC's MySpace |
really? thats awesome. i've never done a build it yourself kit before though. is it hard?? like is it worth doing for a kid who hasnt done that before?? i dont wana accidentally cut a wrong wire or w/e and break it.... |
Look for a used (because that's all there is) DBX 242. Designed by Robert Orban and pretty fully featured. They do sound pretty good. Run about $125 or so on e-bay. I have two and they are emminently usable even though I now have better EQs. Do a search in Gearslutz where Mr. Orban actually discusses the design of the unit and possible mods to improve it.
Yeah I'm an attorney, but everyone needs a day job. |
Are you recording using a computer and recording software? If so, for the money you have in your budget, you will probably get better results with a software EQ plug-in.
On your list it says you are using Pro Tools 7. Doesn't that already come with a parametric EQ bundled in with the software? I can understand why some people want hardware compressors to lightly compress signals before they hit the D/A converters, but it seems like a hardware EQ, unless it is really high quality (which your budget rules out) is not all that essential. What is your rationale for wanting one? From your list, it looks like there are a lot of other areas I would spend money on before an EQ. |
For what it's worth...
The EQ3B is a nice little unit. I don't know where the noise comment came from, but mine is very clean and can be very surgical if you need it to be.
Jay |
I double and triple check every step as I go, and so far every kit I've built has worked right first time......so far..... But if you have experience soldering, and you have a basic knowledge of components and PCB's, and you have good finger dexterity, then it's definitely a great little parametric eq to have in the rack. I cant believe how quiet it is. They have one that's mono 4 band, and another one that's 4 channels with 1 band per channel.....but you can daisy chain the channels....
i don't think paia makes the kit any more. they still have the pcb available though, unfortuntaely it makes it THAT much harder for a beginner
im using acid 5.0 as of now, because my pro tools is at my dads in bum fuck nowhere.... so until i get it back to put onto my compuetr i now use, im using acid. i know i need other things before the eq, but like i'm not even sure where to go next. so i figured i'd go with that. my rack is pretty finalized after the lexicon comes in the mail, but im not even sure what to buy next. any suggestions?? my guitars come out beautifully recorded along with bass/drums. just vocals arent up to par with everything else yet. possibly buy a rode NT1?? |
#12
#13
you could get a blank faceplate and drill it out yourself...? aluminim is a cinch to drill. |
#14
Heck yeah, design a custom faceplate at Frontpanelexpress. That would be cooler anyway (although costlier). I didn't know PAIA had an EQ kit either. I did their 6-channel headphone amp kit and it turned out pretty good for $85 or whatever. two of the channels are mono for some reason, but I still have 4 good ones!!!
Sounds better to me than other commercial units I have used. It was a bit of a pain in the buttocks though, with all the little wires running everywhere. Definitely took some dexterity and patience. buryher - I'm not sure I understand why you think you need something like this? Why not just save up your money for a really good vocal mic if that is the thing holding you back most?
http://www.nationalaudiocompany.com |
