Patch cables, TS or TRS?
I have the M308 mixer. I know the channel inserts are TRS and I'll use a TRS split to two TS patch cables for compression etc but when patching effects through the send/returns should I be using TS or TRS cables? My Zoom RFX 2000 says the 1/4 are TRS but I've been using regular TS cables and they seem to work fine. What would be the difference if I used TRS?
Thanks, Jodi |
there shouldn't be any difference. what makes a TRS jack work is an extra conductor that makes contact with the ring. a mono jack just makes contact with the tip and sleeve. so unless you've got some funky jack that's going to touch the ring instead of the sleeve, you're going to be fine.
Thanks a lot
Well.....depending on what you are patching in, you may lose about 6db by using TS. I think; right?
http://www.nationalaudiocompany.com |
Also you will have an unbalanced signal instead of balanced, which may not be a problem if you are using short cables or are not in an electronically "noisy" area.
I don't use a patch bay and all patch cables are only 6 ft long max. I just didn't know why most patch cables seem to be TSR because the bundle that came with the mixer I bought are all TS, but a few of them aren't working of have shorts etc so instead of fixing them I figured I'd get some fresh new cables so all is well. Do these cables look like they are decent? Patch Cables
Thanks, Jodi |
i'm skeptical of anything advertised as:
THE ABSOLUTE BEST *INSERT ITEM*!!!!!1one |
Understand, but with over 18,000 100% postitive feedback isn't it safe to assume they provide good gear? I mean how can anyone have THAT much feedback and not? I don't know, thanks for the post.
i was kinda joking, they're probably fine cables. i make my own so....
the moral of the story is patch wisely ![]() |
Well, being that the manual says that the send and return jacks are TRS, I would have to assume that they run a balanced signal; in which case using an unbalanced TS cable will lose you about 6db of signal. But if he is patching in unbalanced equipment anyway, it won't really matter as the return signal will be unbalanced no matter whether a TS, TRS, TSR, or whatever other cable is used.
| midimonkey wiring | frederic | Studio Building & Display | 7 | 11-25-2005 21:33 |
| Patch Cables??? | WERNER 1 | The Rack | 10 | 09-19-2005 14:19 |
| Buying TRS cables | rui | Other Equipment and Reviews | 3 | 08-06-2004 01:36 |
| Good patch cables??? | rtzstudios | The Rack | 6 | 08-12-2002 13:38 |
| Need recommendations for Cables and Patch Panel | JJM | Fostex Forum | 3 | 09-16-2001 20:10 |
