Old 07-09-2006
dzara 4 dzara 4 is offline
Junior Member
dzara 4 has a reputation beyond reputedzara 4 has a reputation beyond reputedzara 4 has a reputation beyond reputedzara 4 has a reputation beyond reputedzara 4 has a reputation beyond reputedzara 4 has a reputation beyond reputedzara 4 has a reputation beyond reputedzara 4 has a reputation beyond reputedzara 4 has a reputation beyond reputedzara 4 has a reputation beyond reputedzara 4 has a reputation beyond repute
signal chain question
im brand new to this so i hope i make sense asking this question.
What arrangment in your opinion works best in regards to a signal
chain.
mike --- pre amp ----compressor--- eq's ---- workstation
or possibly
mike---- gate--- compressor --- pre amp --- eq --- workstation
or anything else you can think of.
would love some advice
thanks
Old 07-09-2006
chessrock's Avatar
chessrock chessrock is offline
Banned
chessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond repute
Personally, I think it should go preamp > compressor > gate > microphone.
All the great hits of our time were secretly done that way. Try it.
Old 07-09-2006
NYMorningstar NYMorningstar is offline
Recording Modus Operandi
NYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond repute
I'd say mic->pre->workstation. The shorter the chain the better IMHO.
Old 07-09-2006
soundchaser59's Avatar
soundchaser59 soundchaser59 is offline
Reluctant Commander
soundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond repute
For recording:
mic - preamp - record.
Then if you need compression, do it on playback. My comp has a gate built in, so that is easy enough. I like to compress after eq, cuz eq tends to mess with levels. (unless it is an insert, many of which are pre-eq).
But if you must compress going in, I like to do mic - preamp - compress+gate - record. Try not to eq on the way in.
Just think how good you could play if you were sober!
My Little Corner Of The World
SC's MySpace
Old 07-10-2006
littledog's Avatar
littledog littledog is offline
Three Thousand and Counting
littledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond repute
Gating while recording is very dangerous - you could render the whole session useless. Almost no reason to take that chance - you can always add in the gates at mixdown.
signal chain rightbrainnow Other Equipment and Reviews 6 05-23-2006 01:13
Signal chain question Shakuan Newbies 1 11-26-2004 08:50
Signal Chain & Tascam 564 Digital Portastudio Stratocaster TASCAM User Forum 3 03-29-2003 16:24
signal chain question mrmetal Recording Techniques 2 01-09-2003 05:14
STANDARD/BASIC signal chain bunnygirl Recording Techniques 17 01-05-2002 20:33
