Old 07-08-2006
Rocket Boy's Avatar
Rocket Boy Rocket Boy is offline
Force of Nature
Rocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant future
Controlling offensive tones...
I can't seem to get rid of this really nasty overtone on my acoustic guitar on a song. Any tips?
Old 07-08-2006
mitosis's Avatar
mitosis mitosis is offline
Registered Abuser
mitosis has a reputation beyond reputemitosis has a reputation beyond reputemitosis has a reputation beyond reputemitosis has a reputation beyond reputemitosis has a reputation beyond reputemitosis has a reputation beyond reputemitosis has a reputation beyond reputemitosis has a reputation beyond reputemitosis has a reputation beyond reputemitosis has a reputation beyond reputemitosis has a reputation beyond repute
A little more info would help. Maybe list the equipment.
Old 07-09-2006
soundchaser59's Avatar
soundchaser59 soundchaser59 is offline
Reluctant Commander
soundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond repute
double post
Just think how good you could play if you were sober!
My Little Corner Of The World
SC's MySpace
Old 07-09-2006
Halion's Avatar
Halion Halion is offline
1K Silver Member
Halion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond repute
A super sharp notch (or band pass) filter would do very well. All you have to do is home in on the offending frequency and turn it down (most of the time a 6db cut is enough to tame even the most offending frequencies. You probably don't wanna get rid of it all together, but just make it less offensive).
Old 07-09-2006
Reluctant Commander
can you post an example?
is the guitar resonating? same pitch every time? is it only heard in the recording? only when using the mic? or do you hear it even when you are just playing the guitar in the room and not recording? which mic? if you have another guitar, do both guitars do the same thing? what recorder? do you have a parametric eq available?
SC's MySpace
Old 07-10-2006
thediscoking's Avatar
thediscoking thediscoking is offline
Junior Member
thediscoking is a jewel in the roughthediscoking is a jewel in the roughthediscoking is a jewel in the rough
Try running the track through a frequency alalyzer plug in. You can usually see what's annoying you and you can EQ it.
I'm with the other people... give more details!
Old 07-10-2006
xistenz's Avatar
xistenz xistenz is offline
Senior Member
xistenz has a reputation beyond reputexistenz has a reputation beyond reputexistenz has a reputation beyond reputexistenz has a reputation beyond reputexistenz has a reputation beyond reputexistenz has a reputation beyond reputexistenz has a reputation beyond reputexistenz has a reputation beyond reputexistenz has a reputation beyond reputexistenz has a reputation beyond reputexistenz has a reputation beyond repute
are you sure it's not your room? if your room has a mode where you're hearing the overtone, especially if your guitar resonates at that same freq or a multiple thereof, you might have to treat the room. or try recording in a different room.
Old 07-10-2006
Chibi Nappa Chibi Nappa is offline
Force of Nature
Chibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond repute
Man, don't EQ it out! You gotta' move your mic, swap out your mic, change positions in the room, change rooms, etc until you record it right in the first place. Leaning on EQ to fix it in the mix will never teach you anything, and never sound as good.
Old 07-10-2006
littledog's Avatar
littledog littledog is offline
Three Thousand and Counting
littledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond repute
Yes, but if it is too late or otherwise impractical to start the whole session over from scratch, EQ notching might be your only fix.
Poll: Best Bass Tones..and worst? clifchamb Guitars and Basses 11 12-17-2007 16:25
Controlling offensive tones... Rocket Boy Recording Techniques 5 07-11-2006 10:19
Recording test tones on a reel. Newbie needs help. Grenouille Analog Only 3 02-09-2005 10:55
Changing drum tones Timbecile Recording Techniques 6 03-26-2004 12:45
Classic amp tones too boomy shagfu Mixing / Mastering 11 11-10-2002 20:18
