Old 12-22-2000
oneArtist oneArtist is offline
Senior Member
oneArtist is on a distinguished road
Hello all,
I just ordered a D824($1500 from http://www.digitalproaudio.com), and it will export WAV files to a SCSI II fixed or a JAZ SCSI as well as record on a IDE interal drive. I am SCSI ignorant and I need to know how to set-up an external SCSI II box and what do I hook it to, a PCI SCSI controler? Also, what is the fastest SCSI II I can get. I may send out Samplitude/Logic files out to the SCSI box as well as use the D824 export.
Thanks,
Chuck
Old 12-22-2000
skippy's Avatar
skippy skippy is offline
1K Silver Member
skippy is a glorious beacon of lightskippy is a glorious beacon of lightskippy is a glorious beacon of lightskippy is a glorious beacon of lightskippy is a glorious beacon of light
Hmm. Well, this technique is best referred to as "sneakernet": the drive can only hook up to either the D824 or your PC thing one at a time- not both. Both are SCSI bus masters, and the SCSI drives can only talk to a single master at a time. So there is no way to plug a drive into both at once.
I frankly don't know a thing about setting up a SCSI adapter on a pc- I don't use them as yet, being a UNIX guy with native SCSI-based systems. You'll need to query some of the PC-based folks for that one. I'm sure that it will involve getting a PCI SCSI adapter up and running. However, once you do get that set up, you can format your external drive using DOS format commands with the old DOS FAT16 filesystem. This is all the 824 understands for .WAV export: the old filesystem with a max of 2 Gb.
When you're done with that, you can power everything down (SCSI is _not_ a hot-swap technology!), unplug the drive from the PC, carry it over to your D824, plug it in, power everything back up, and use the utility menu to write .WAV files to the DOS-formatted drive. The D824 "format" command *cannot* do DOS formatting. It can only do Fostex FDMS3 formatting, which is completely proprietary and useless to anyone but a Fostex box (but semi-convenient for backups). For .WAV export, all formatting must be done on the PC...
When you're done with writing the .WAV files on the DOS-formatted disk, you can power everything down, unplug the drive from the D824, carry it over to your PC, plug it in, power everything back up, and access the .WAV files.
Sneakernet. This basically rots. My take on this is that it is vastly preferable to have a pair of Jaz drives that remain permanently connected, and just carry the media (which *is* hotswappable!), rather than drag an actual hard drive back and forth. In my experience, SCSI cables do not like continual plugging and unplugging, so hard-drive sneakernet is a failure waiting to happen.
The speed of the SCSI-II adapter is pretty much a nonissue. SCSI-II is 10Mb/sec, and that's it- and the D824 and the removable-media drives can't go that fast anyway. Dumps to SCSI on my machine actually do not appear to be significantly faster than real time. Which is why the DAW I've been trying not to build will have 16 channels of ADAT in/out, so that I can just ship the data over optically from my D1624 (at real-time speeds) to the DAW (and vice-versa) and avoid the whole sneakernet hassle altogether...
I'm not a big fan of Fostex's SCSI implementation: it is clearly an afterthought, and a kluge at that.
Hope that helps.
Old 12-22-2000
Senior Member
The Multitrack/PC connections
Skippy,
I appreciate your complete answer. Very few people seem to know much about this set-up.
I have two Pulsar 1 cards updated to 2.01. in an Athlon 650MHz w/384mb SDRAM on a ASUS K7M mobo(I just read a review on this board and ASUS deviated from the usual AMD rules and AMD doesn't recommend it but the reviewer said it is an overclockers dream. He said ASUS isn't saying much about it to protect their Intel priviledges) That gives 16 I/O ADAT, 4 SPDIF, 8 analog I/O, and 2 I/O ea of Midi In, Out, and Thru. I also have an ADAT/TDIF converter to a Tascam TMD-1000 mixer. I may try the ADAT route from the 824 into the computer(32bit processing both in Pulsar and Samplitude 2496) It is strange to import a song off a commercial CD and process it with Samplitude and transform it to a much better sound.
I could also try putting a few WAV file in my little Iomega zip 100.
I may be of some help to you when and if you assemble a DAW. I have about one years worth head knowledge and a good dose of what works with what.
Chuck
Old 12-22-2000
skippy's Avatar
1K Silver Member
That's outstanding news...
Defintely go the ADAT route, and never look back. IMNSHO, forget SCSI altogether. In your case, you can already ship data up and down via ADAT in real time. SCSI drive-swapping (plus the miserable transfer rate) means to me that you prbably already have all the hardware you need, and more overall throughput... I believe that ADAT lightpipe is the best way to deal with the Fostex HDRs, in general.
I may call on you when I make that final death-spiral down the DAW rathole. I bought the D1624 primarily to try to avoid it, but the longer I go down the digital route, and the more potential clients I talk to, the more I realize that it is inevitable!
