Old 07-08-2006
schismatic schismatic is offline
Junior Member
schismatic has a reputation beyond reputeschismatic has a reputation beyond reputeschismatic has a reputation beyond reputeschismatic has a reputation beyond reputeschismatic has a reputation beyond reputeschismatic has a reputation beyond reputeschismatic has a reputation beyond reputeschismatic has a reputation beyond reputeschismatic has a reputation beyond reputeschismatic has a reputation beyond reputeschismatic has a reputation beyond repute
Realistic sounding double kicks and drum rolls
Hi guys,
I'm doing a cover of a song and I have a midi file of the drums for it (it's Schism by Tool). I am use Cubase to sequence the thing. All sounds very nice except for when the drums play double kick patterns i.e lots of bass notes together, fast. When this happens I tend to get very unrealistic, 'drum machine' sounding notes. I am aware of the velocity variation as a way of making it sound a little less rigid, but I was wondering if anybody who was into any sort of metal where such drums are used could give me some good tips on how they go about getting a good sound. I have decent samples (drumkit from hell where a kick is recorded at about 8 different velocities to give a range) but I have no idea how to really take advantage of the samples to get a great sounding and hopefully realistic sounding kit. The same thing happens for me with tom rolls too, they're often sounding rigid, unnatural, almost too 'in time'. I'd love it and be very grateful if somebody could talk me through how they'd go about programming, adjusting etc and what particular software they like to use to do thi (DKHS, Battery etc)
Cheers!
Old 07-08-2006
metalhead28's Avatar
metalhead28 metalhead28 is offline
Hates Raymond
metalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond repute
About all you can do is vary the velocity and timing a little. You could also cut down the volume a little in those sections.
Sometimes a slightly mechanical sounding kick drum roll sounds fine in a full mix anyway. Have you listened to it like that?
Some of my music
Old 07-08-2006
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
In your situation, you would need to vary the velocity. The drum machine sound iis from the same sample triggering every time. You need to make it so that the sequence triggers different samples every time. If you have Drumagog, you can make your sequence trigger the Drumagog samples which are multi-sampled. That way, even at the same velocity, different samples get triggered every time.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 07-08-2006
Junior Member
thanks for the input guys.......i haven't tried it in a mix no, i'll try that at some point. am i right in understanding that say i have a 16 note bar of kick (4/4 time) that drumagog would be able to accurately replace individual notes with different samples done at different velocities in a quick and effective manner?
oh yeah one more thing, as far as timing variation goes just how much is effective and how would i go about doing this? do i just slightly nudge notes in a midi editor or something? could i run them through some sort of thing that varies timing slightly by say 1-5%?
Old 07-08-2006
TragikRemix's Avatar
TragikRemix TragikRemix is offline
I am NOT a Gear Whore. ;)
TragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond repute
i think (depending on your software) you can do something along the lines of 'quantize velocity' and set it to something like 'humanize' or 'randomize' by XX%
i use DFH for midi. it rawks.
GFCG Member: 000 029
F**k Your Scene.
Old 07-08-2006
and the second question- that should be in your quantize settings, where you can vary how exact you want it to be.
F**k Your Scene.
Old 07-08-2006
Farview's Avatar
it can go as fast as it needs to. Cubase is latency compensated, it will just work.
Jay Walsh
Old 07-08-2006
Superhuman Superhuman is offline
Shagaholic
Superhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond repute
DFHS has a built in quant feature that uses a number of different samples for each drum, each sample is a separate shot on the drum so it sounds way more organic than just changing the velocity on a standard 'one sound per drum' set up. You can set the velocities to change as you see fit to make things even more realistic. It sounds pretty damn convincing on a steady beat, rolls also sound great - there are plenty of downloadable midi files mapped for DFHS (makes things a lot easier than programming every single beat). Check it out.
Some 7 string shred...
Old 07-08-2006
Junior Member
thanks for those suggestions, the DFHS thing about triggering different samples sounds just what I'm looking for. can any other software do this i.e. bfd or else?
Classic Hip Hop Tools/Method peritus DJ & Hip Hop Production 9 04-06-2006 22:04
Alesis sr-16 assigning double bass kicks to 1 pad Digimortal Alesis Forum 7 09-23-2005 14:01
I really need some help with technique. Looking for pointers. Lempface Recording Techniques 17 08-29-2005 17:09
Drum Recording Help BATERIA71 Recording Techniques 4 06-11-2005 11:36
Removing Drum Kicks? barefoot Mixing / Mastering 1 03-11-2002 15:27
