Old 07-07-2006
dirtydoo dirtydoo is offline
Junior Member
dirtydoo has a little shameless behaviour in the past
can word clock replace midi
i just got this m audio 1814 for a soud card for my laptop. i was looking at it and i notice it had word clock on it, i dont know a hole lot about word clock but i remember over hearing some people talk about it an d they said it could replace midi for syncing and it was wa better than midi. is this ture
Old 07-07-2006
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
no way.
MIDI and Word Clock are two different things. First of all MIDI has been around since the 80's and I don't see it going anywhere anytime soon.
secondly, word clock is a way of keeping a constant bit rate signal in your digital gear to help avoid errors in the data stream. This has nothing to do with MIDI which is a form of a digital language.
Word clock doesn't have anything to do with syncing in relation to time code either.
To use the word clock in your device, you'd need something that generates word clock. Which you don't need unless you're running multiple pieces of digital gear. An example of a word clock you could purchase is this.
www.redlabaudio.com
Old 07-08-2006
Junior Member
Originally Posted by bennychico11
no way.
thanks for clearing that up for me
Old 07-08-2006
Farview's Avatar
Farview Farview is online now
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Just to elaborate on Benny's point:
word clock is for syncing up all the digital clocks in a system so that they are all cycling at the same time. There is no timecode information in wordclock.
Midi sync is timecode.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 07-08-2006
TragikRemix's Avatar
TragikRemix TragikRemix is offline
I am NOT a Gear Whore. ;)
TragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond repute
is word clock syncing necessary? i have a digi 002 and a behringer ada8000, should connect their wordclocks? im using the ADAT from them, so is that the same?
GFCG Member: 000 029
F**k Your Scene.
Old 07-08-2006
Farview's Avatar
When you are just syncing two units together, you can just slave the one off the other through spdif, ADAT, AES/EBU, etc...
When you have an entire room full of stuff that all needs to be in sync, wordclock.
Jay Walsh
Old 07-08-2006
littledog's Avatar
littledog littledog is offline
Three Thousand and Counting
littledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond repute
If you don't set one to be the master and the other the slave you will hear random clicks. You'll see them on the meters too.
Old 07-08-2006
yep ive experienced the clicking from hell. so the adat syncs the two units, because thats all i have?
F**k Your Scene.
New Rep Point Thread. DJL Prime Time 114407 3 Days Ago 16:35
FL Studio as a MIDI sequencer? HairWuzEre Keyboards and Sound Modules 1 10-21-2004 12:37
Quick Question sarkastic714 MIDI Mania 1 09-21-2004 06:21
cubasis vst 4.0 midi clock send? grobshnit Cubase User Forum 0 10-03-2003 15:00
