need a pot value for a small project
i'm going to be building a small monitor switchbox/passive volume controller for my DAW this weekend. i have everything else sketched out, but i'm not really sure what value pot i should use for the volume knob. my gut tells me 10k will work, but i'm not sure. this is for line levels out of my soundcard into powered monitors that have input impedence of 20k.
200K to 1 megohm pot should work nicely.
cool, thanks!
I would say at least a quarter ounce.
Orson as in mork & mindy not the shit band, they are really shit. |
Pot value for a small project?
commercial - $60/oz Kin - $200/oz |
Not exactly pretty, but it should work fine. |
i ended up using a cheapo 50k because that's all the store had. two problems; it doesn't track evenly, and the resistance isn't sufficient. even tracking is desirable because at lower volumes one side is audibly higher than the other. higher resistance is needed to make the knob less sensitive at lower volumes; i.e. the slightest movement causes big jumps in volume at low volumes. a higher value pot will even that out.
i'm looking into an alps blue velvet 200k dual, just trying to find a place that sells them. ebay might be a good source. just have to be patient. but otherwise the knob works! no more screwing around with the little software mixer app every time i need to adjust the volume on my monitors ![]() |
As I said in my first post here, "200K to 1 megohm pot should work nicely".
#12
I think you will want a 1 meg dual (stereo) audio taper pot...anytime you use two seperate pots the tracking will be off and a linear taper is a little wierd for volume control in an audio setup...Ratshack won't have it..try mouser.com or digikey.com..audio (or log) taper...reverse log taper if you can find it (good luck on that one
...60 beans an oz? I think I am moving to your town!!!! ![]() Ray |
#13
yep, i know, i grabbed the cheapo because it's all they had at the time and i figured i could get the whole thing put together while i found a good one in the 200k to 1M range.
the alps blue velvet series are dual log taper conductive plastic pots. they are what a lot of hifi diy folks like to use, aside from stepped attenuators which are another option. all the mouser pots that are worth buying (alps, bourne) have obscene minimum quantities. the only ones they sell individually are taiwaan crap jobs. digikey has nothing worth buying. |
#14
I was just thinking...$60 an ounce has never been seen by me...when I was a teen and knew such things it was like $60 a quarter...
War |
| Speaker for a small aerobics room | ambi | Mixing / Mastering | 2 | 06-06-2004 14:04 |
| Small project question | Rhino_Rick | Recording Techniques | 6 | 12-04-2003 17:46 |
| small, rectangular studio | Shorty Edwards | Studio Building & Display | 2 | 01-02-2003 13:14 |
