Power Problem
Hi guys,
I'm hearing an electrical buzzing in my headphones . Last night I moved some gear into my living room and did a test. I sat on the ground and slowly moved my mic in different directions. I heard a loud buzzing in some spots and soft buzzing in other spots. Regardless, there was always a buzz.Just so you know, I took my mixer to another location and it sounded clean. So I think it's the power in my house. All the outlets in my house produce this buzzing. I've checked my cables...Not the problem. Would a power conditioner solve my problem? Any thoughts? |
Are you free from any wireless devices in the room? I know that my cordless phone receives weird radio signals whenever it enters my room due to a wireless router.
There is a cordless phone in the room...I'll try moving that out of the area...It's interesting, I've managed to get a nice quiet signal when I place the mic under the doorway in my room. However, that's not really ideal. Hummm...
Some cordless phones share the same frequency as wireless routers... that's the issue there...
if moving the mic around results in varying degrees of AC hum... then you're dealing with RFI... a power conditioner will have no effect on this... it's radiating from a power conductor with bad shielding... or a dodgy connection... Do you have high tension lines or secondaries outside of your house... it could be a bad splice or insulator on the pole... a call to the power company would fix that. A good way to find radiating power "leaks" is with an AM radio... tune slighty off channel and listen for the buzzing as you wander the neighborhood... |
Interesting... I'm going to investigate! Thanks.
Ebtech HUMX Voltage Hum Filter
what about something like the Ebtech HUMX Voltage Hum Filter?
Looks like you investigated the internet instead of the source of your hum
Hmmmmmm...? |
Yeah, I know...
Taking the internet way out... ... I suppose you're right, I'll continue my investigation by calling my electical guy. |
Did you have your mixer anywhere neay your computer monitor?
CRT computer monitors emit a lot of EMI. |
It's interesting, man! |
Good luck!
Got any Irish in ya? Want some? http://i40.photobucket.com/albums/e2...shedvsmall.jpg |
#12
Doing the test, right now.
#13
I'm going to go out on a limb and suggest that one of two things is probably wrong: either your mixer's chassis ground isn't properly grounded or its signal ground isn't properly grounded. This is probably due to a bad ground on the outlet.
To verify that theory, get a heavy gauge extension cord and, leaving the mixer exactly where it is, power it from the outlet where it did not hum. If it still does not hum, your outlet is not properly grounded.
| Power supply problem | PhilGood | Microphones | 48 | 04-06-2005 19:19 |
| What is this problem?! A phantom power issue? | teainthesahara | The Rack | 11 | 09-10-2004 11:11 |
| power conditioner problem :( | tomleblanc | The Rack | 1 | 06-18-2003 17:42 |
| Tx81Z problem / power supply replace ? | smop | The Rack | 3 | 09-26-2001 14:36 |
| The power problem!!! | Spider | The Rack | 9 | 07-28-2000 05:23 |
