I have just reinstalled my Multimix 8 Firewire for the umpteenth time. The manual specifies a shutdown (and startup sequence) which is:Multimix first then computer and reverse for shutdown. As a general rule I don't shut down my computer so why do I lose the Multimix? Sometimes a clock reset will do the trick and other times I am unable to access the control panel.
Any thoughts? |
Just received this from Alesis.
Hello, I would recommend updating to the latest drivers from off our website. Before doing so, the old Multimix drivers would need to be uninstalled from the Windows Control Panel> Add/ Remove programs section. Anything that has the words “Multimix” would need to be uninstalled. After the update, it will not matter what order the Multimix is powered off. Also are you using a 6 to 4 pin firewire cable? If so, these are unstable and can cause dropouts. We just recommend using a 6 pin firewire cable. Also another firewire cable can be tried. Sincerely, Justin Baro Technical Support Numark || Alesis || Akai Professional || Ion Audio 200 Scenic View Drive Ste. 201 Cumberland, RI 02864 P: 401.658.5760 F: 401.658.3640 |
Interesting.. They told me the 4 wire cable of the 6 was fine.. The other two wires on the 6 wire are for power on Firewire powered devices...
You're not using a Celeron processor PC are you..??? -- Rob |
Pentium 4 2.00Ghz Dell 4700
| Alesis Multimix 16 USB | dognoise | Alesis Forum | 4 | 05-27-2006 06:48 |
| Alesis Multimix - High pitched noise with usb connection | fnord12 | Recording Techniques | 0 | 03-02-2006 20:32 |
| Alesis multimix experience anyone? | jes | Alesis Forum | 8 | 08-06-2005 15:36 |
| FS: Alesis MultiMix 16USB Mixer with USB Audio | zeav | Free Ads for Music / Recording Equipment | 0 | 03-12-2005 12:18 |
| alesis multimix anyone? | jes | Mixing / Mastering | 0 | 02-09-2004 21:27 |
