Old 07-05-2006
Chris F's Avatar
Chris F Chris F is offline
Dedicated Member
Chris F has a reputation beyond reputeChris F has a reputation beyond reputeChris F has a reputation beyond reputeChris F has a reputation beyond reputeChris F has a reputation beyond reputeChris F has a reputation beyond reputeChris F has a reputation beyond reputeChris F has a reputation beyond reputeChris F has a reputation beyond reputeChris F has a reputation beyond reputeChris F has a reputation beyond repute
Controlling toms in the overheads
When recording jazz trio with my modest setup (MOTU 1224/Digital Performer on a Mac) in a decent sounding room, everything is working pretty well except the level of the toms in relation to the rest of the kit in the overhead signal, as in behind the piano solo on this cut. The toms jump out so much at times that it limits the dynamic range of the entire recording and bottoms out a couple of times. The overheads are MXL 603's running into a DMP3, and except for the toms, the level on the pre is pretty low. What can i do to lessen this effect? Raise the mics up? Spread them out? I really don't want to use a limiter on the way in, but since I'm playing bass on all the stuff I record, I can't do anything but set the levels and turn the recording on and off.
Any and all suggestions welcome.
Wherever you go, there you are.
www.chrisfitzgeraldmusic.com
Old 07-06-2006
NYMorningstar NYMorningstar is offline
Recording Modus Operandi
NYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond repute
I listened to this 2X and did not feel your pain.
You should post this in the MP3 clinic for more reviews.
http://homerecording.com/bbs/forumdisplay.php?f=15
Old 07-06-2006
RAMI's Avatar
RAMI RAMI is offline
www.ramirami.com
RAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond repute
Can you tell us what your overhead mic configuration is?
Old 07-06-2006
andydeedpoll andydeedpoll is offline
i do love smilies...
andydeedpoll has a reputation beyond reputeandydeedpoll has a reputation beyond reputeandydeedpoll has a reputation beyond reputeandydeedpoll has a reputation beyond reputeandydeedpoll has a reputation beyond reputeandydeedpoll has a reputation beyond reputeandydeedpoll has a reputation beyond reputeandydeedpoll has a reputation beyond reputeandydeedpoll has a reputation beyond reputeandydeedpoll has a reputation beyond reputeandydeedpoll has a reputation beyond repute
i thought it sounded fine, and i have to say i did really enjoy listening to that kinda soulful and quirky at the same time. clever music
Andy
"They're posh round 'ere. They get out of the bath for a piss and Everything."
Old 07-06-2006
Chris F's Avatar
Dedicated Member
Thanks for the comments - you guys work quick! The overheads were about 5 and 1/2 feet high, and [sort of in a crossing pattern, with each on on a boom stand to the left and right of the kit, each aimed at the cymbal on the opposite side. Listening back, I think both the snare and toms are too hot, and they are the only thing that triggers the last 6 db of headroom on the meter.
Should I have started this thread in the MP3 clinic? D'oh!
Old 07-06-2006
bigtoe bigtoe is offline
Force of Nature
bigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond repute
try either or both raising the mics and/ or pulling the mics back more over the drummer's head...you could also try cutting some lower mids...like gently cutting starting around 500 with a shelf eq.
the positioning will help you most though...at least it does me... particularly the backing the mics over the drummer's dome.
Mike
www.independentrecording.com
"the first step to having 300-1000 shrink-wrapped CD's under your bed."
Old 07-06-2006
blueroommusic's Avatar
blueroommusic blueroommusic is offline
you want this big boy?
blueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond repute
If you are going to use a "semi-crossing" pattern, you need to be a bit more exact...X/Y configurations can be testy if you don't get the capsules lined up right. make sure they are as close to a 90 degree angle as possible...and move them around...you might even have to move them around alot to find the sweet spot...the main thing you want to focus on is getting the best overall mix of the drums...
I didn't listen to the track, so I don't know what kind of skill level your drummer is playing at, but he could be "dynamically challenged"....studio drummers are used to playing a kit in the studio...they know HOW they need to play, what kind of dynamics they need to play with to get the right mix of their drums into the overheads....
I come from the taint of America, so don't bitch at me about your f*#@ing problems. You don't have to wake up everyday smelling like a mix of ass AND balls.
Old 07-06-2006
RAMI's Avatar
www.ramirami.com
I agree...It can't be "sort of" X/Y. If the mics aren't 90 degrees to each other, you're inviting problems.
Old 07-06-2006
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
Another $.02 thrown into the hat...
Very nice recording! The stand up particularly sounds good, not an easy thing to do all the time.
I generally agree with the rest that I don't see the drums as that much of a problem. In fact, I'd be quite hesitant about pulling back the OH's as the drums already have a fair amount of "room" included with them, I wouldn't want to make them much more reverberated and distant than they alreay are.
That said, I do hear what you might be worried about starting right around the 3:30 mark and going from there as the trio slowly crescendos through the rest of the piece.
I do have a couple of suggestions that are not set in stone, but you might want to explore...
First, if I were riding the desk on this one, I'd be *really* inclined to seperate the instruments in pan space in the manner of many classic jazz trio recordings. Not any hard panning (except for maybe some stereo room reverb returns that you may have happening), but setting a soundstage as if the listener were in the audience of a smoke-filled jazz club. Something like piano maybe 35-50% left, bass up the middle and the stereo drum OHs tight-panned between about 30 and 60% right. Not only does this impart a classic jazz feel to the mix, but it would also help keep the drums from stepping on the piano without having to worry about the levels so much. This levels thing is especially important IMHO, because I don't think I'd want to sacrifice any more hat and brass from the drums just to satisfy the toms; I wouldn't want the cymbals much weaker.
Second, perhaps using a volume automation envelope on the drums across the entire piece, as the levels are dramatically different at the beginning and the end as the band puts more energy into their playing. Governing those levels over time with a gentle envelope slope - at least on the drums if not on the whole mix - may help tame the toms and snare a bit.
And, unrelated but worth mentioning; I'm not sure, but I think I heard some bad beat frequencies in a couple of the piano chords. It's always harder to tell with some of the oddball jazz chords, but I *think* maybe the piano might be in want of a fresh tuning. If you haven't had it tuned recently, then it moght be something to look into; if it has, then ignore this as being fooled by a couple of unexpected but intended jazz dissonances. .
But all in all, very nice work on both sides of the cables. A pleasure to review. Is it nice to hear something other than doubled and hard panned distortion guitars on these boards
HTH,
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
Old 07-06-2006
sweetnubs's Avatar
sweetnubs sweetnubs is offline
Force of Nature
sweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond repute
Tell the drummer not to hit the toms as hard. Fucking musicians nowadays, they want us to do the work they're supposed to be doing.
Old 07-06-2006
sweetnubs's Avatar
Force of Nature
That is of course you got your mics positioned right. Overheads, get 'em up high.
  #12
Old 07-06-2006
slidey's Avatar
slidey slidey is offline
Happy Legs Fingers Davis
slidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond repute
couldn't agree more
I think I'll have a listen to the track now.................
BOING!!!!!!!
G.F.C.G membership No# : 000 042
boingaroo aka wannabe drumber
  #13
Old 07-06-2006
xistenz's Avatar
xistenz xistenz is offline
Senior Member
xistenz has a reputation beyond reputexistenz has a reputation beyond reputexistenz has a reputation beyond reputexistenz has a reputation beyond reputexistenz has a reputation beyond reputexistenz has a reputation beyond reputexistenz has a reputation beyond reputexistenz has a reputation beyond reputexistenz has a reputation beyond reputexistenz has a reputation beyond reputexistenz has a reputation beyond repute
are you sure it's not your room that's making the toms jump out? they sound fine to me.
  #14
Old 07-07-2006
Dani Pace's Avatar
Dani Pace Dani Pace is offline
Why 2K?
Dani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond repute
Drums are tricky, I think of it this way... with drums you are not recording a single instrument, each drum and cymbal is a seperate instrument. Mic placement to record them all takes very carefull adjusting to find that sweet spot where everything is balanced. A few inches can make a big difference. Patience and experimentation are the only sure ways to find the best mic placement, and every drummer/drum set is different.
For what it's worth, I'd rather record a jazz drummer than some heavy handed rock star wanna be, it's a lot easier.
The more I learn, the more I realize how much I don't know. http://www.soundclick.com/sixfeetover
  #15
Old 07-08-2006
funkydrummer funkydrummer is offline
Junior Member
funkydrummer has a reputation beyond reputefunkydrummer has a reputation beyond reputefunkydrummer has a reputation beyond reputefunkydrummer has a reputation beyond reputefunkydrummer has a reputation beyond reputefunkydrummer has a reputation beyond reputefunkydrummer has a reputation beyond reputefunkydrummer has a reputation beyond reputefunkydrummer has a reputation beyond reputefunkydrummer has a reputation beyond reputefunkydrummer has a reputation beyond repute
i look at drums the opposite way-- as one instrument. i love the way the other drums vibrate when you hit the one... when i think of people trying to isolate every piece of the drums, it's the same thing as mic'ing every string on an acoutic guitar and trying to figure out how to keep the G string out of the A string's mic.
anyway, for small combo jazz drums, you can get a great sound with one or two mics.
tell me... is it more of the same and where can i find it?
how would you mike this HUGE drumkit? 6 toms 10 cymbals earworm Recording Techniques 24 08-01-2006 09:43
Do you ever gate the Toms at the mixing stage? alanfc2 Mixing / Mastering 34 12-23-2005 08:18
drums in living room, HuuUGE toms corban Drums and Percussion 6 03-26-2005 19:00
EQing advice for drum overheads Drummerbones Drums and Percussion 6 03-26-2005 09:10
3 Toms, 2 Mics MrKwik Drums and Percussion 8 03-23-2005 13:01
