Old 07-04-2006
Elementcole037 Elementcole037 is offline
Newbie
Elementcole037 is on a distinguished road
"Reducing Noise" in my recording
Hi, I am a newbie to this forum.
I don't exactly have all the hi-tech equipment that professionals have but I do have the basic stuff like....
Cool Edit Pro 2.0
Behringer 2 channel Compressor
Behringer 2 channel, 31 Band Equalizer
Behringer 4 Mic, 2 input Mixer
1 MXL 993 (Instrumental Mic'in)
1 MXL 990 (Vocals)
I record in a basement,
I was wondering how to reduce the noise in the background in my recording....It isn't horribly bad or anything but still noticable..
Im wondering if there is something I can do that really isn't gonna cost me a whole lot of money.
Is there something in Cool Edit Pro 2.0 that I can do to reduce the noise?
Any help would be most appreciated,
Cole
Old 07-04-2006
littledog's Avatar
littledog littledog is offline
Three Thousand and Counting
littledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond repute
Could you specify if you are talking about external noise (furnace, air conditioner, noisy neighbors, etc.) or electronic noise (hiss, hum, radio stations, etc.)
Please be as specific as possible.
Old 07-04-2006
Newbie
I get alot of hiss in the background...it is probably comming from the ac/furnace......computer and other electronic devices..
Old 07-04-2006
Newbie
here is an example
Here is an example of my work, feel free to tear it to shreds on its "quality" because i could sure use some pointers....thanks
http://www.lightningmp3.com/live/file.php?fid=4170
Old 07-04-2006
littledog's Avatar
OK - if you are pretty sure it is external noise, and not the internal electronics of your recording chain, then the best way to deal with it is to remove it at the source.
That means, while you are recording, turn off your furnace and air conditioning. Build an enclosure around the noisy parts of your computer to keep it from getting into mic. And you can also put some portable barriers around the mic itself (called gobos) to block some of the sound from reaching the mic. Also, assuming the mic is cardioid, aim the mic directly away from the noisiest part of the room.
Old 07-04-2006
studiomaster's Avatar
studiomaster studiomaster is offline
MachWave
studiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond repute
Get the Behringer outta the chain and get a preamp.
Old 07-04-2006
MachWave
Also, compress the vocals. EQ it up a bit.
Old 07-04-2006
Sloan's Avatar
Sloan Sloan is offline
Force of Nature
Sloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond repute
I just got done tracking a band where they insisted on recording the guitars Direct. I wasn't all about it, but it didn't turn out bad at all. There was some noise though, and I spent some time editing the guitar tracks where they made stops in their playing so that that the noise was hardly noticeable. It helped out quite a bit!
sloanstewart.com
Old 07-04-2006
Tim Brown's Avatar
Tim Brown Tim Brown is offline
Why 2K?
Tim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond repute
+1,000%!
Cheap mixers tend to add noise to recordings.
Also, it could be whatever your sound card is, and most likely it is the combination of the two (mixer+soundcard). Hiss isn't caused by "external" sound sources, like an air conditioner.
Tim
Old 07-04-2006
gecko zzed's Avatar
gecko zzed gecko zzed is offline
audio illusion
gecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond repute
I would suggest that you not react to the instant diagnoses presented.
Instead, I would suggest that you work systematically through the signal path to see if there is some part that is primarily responsible for the noise.
Maybe the mixer is noisy, maybe it is the interface. Don't leap into solutions before you've identified the problem.
Old 07-05-2006
Tim Brown's Avatar
Why 2K?
Gecko zzed,
True - he does need to work through his signal chain.
It could be simply a matter of his volume too high on his soundcard, and not sending enough signal from the mixer.
I've got a Mackie 1604-VLZ pro mixer, and we went through everything trying to get rid of the hiss I was getting recording onto my computer, but there was always a little bit of noise present. My brother and I were trying to record live to stereo, and then he was going to layer tracks over top of our Rhythm section tracks.
No matter what we did, there was always a little bit of audible noise in the recording, so I chalked it up to a combination of the mixer and the soundcard.
Tim
  #12
Old 07-05-2006
Tim Brown's Avatar
Why 2K?
Gecko zzed,
Tim
  #13
Old 07-05-2006
Tim Brown's Avatar
Why 2K?
Gecko zzed,
Tim
  #14
Old 07-06-2006
Chibi Nappa Chibi Nappa is offline
Force of Nature
Chibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond repute
Modern gear, even the cheapest of the cheap, should be quiet enough that noise is not an issue. It is most likely the environment or mis-use of the equipment. Turn off everything: The airconditioner, the heat, the 'fridge, the TV, the ice maker, etc. That's most likely the problem. What your everyday untrained ear chalks up as "quiet" is not nessicarily quiet to a microphone.
Barring enviromnetal issues, check your gain structure. For instance, if one bit of gear is turned down way too low and the next bit of gear in the chain is turned up way too loud to compensate, you'll get noise.
So check that gain structure, but my bet is the environment.
Can I get advice from those who have a home studio? Chrisku13 Studio Building & Display 56 08-21-2006 23:20
PC recording, not for the fence-sitters Diragor Digital Recording & Computers 11 02-28-2006 17:26
Best Value Mic(s) for Recording Male Vocals/Martin Acoustics Aceboympk Microphones 20 02-14-2005 13:40
Delta 44 vs. Windows Recording Mixer. God help me. Shepherd Digital Recording & Computers 2 06-09-2003 07:39
