Old 07-04-2006
Superhuman Superhuman is offline
Shagaholic
Superhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond repute
A/D Converters
I currently have a rack mounted M-Audio Delta 1010, the sound has always been pristine to my ears. Recently I went to a studio and recorded a bunch of guitar tracks through an Apogee AD8000... the difference on sound quality was mind blowing! The Delta 1010 looks the business on paper and untill now I never thought otherwise... do I have it set up wrong (interface settings) or is the AD8000 actually THAT much better??
Anyone got any tips on how to get the most out of an AD converter? I record guitar and bass exclusively.
Cheers
Some 7 string shred...
Old 07-04-2006
tmix tmix is offline
1K Silver Member
tmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond repute
My opinion
There are several thoughts on the subject, and you will probably hear them all... conflicting.
To me there are several aspects to the converters and front end to any recording setup. There is the converter itself, some chips are better... how much better?... the better ones have less errors in their calculations that can translate to clearer image. Then there is the clocking mechanism. The better the clock the clearer more focuses and deep the image. Many feel the clocking has more impact than particular chips. Then there is the analogue circuitry at the fron end or rear end after the chip. If you have cheesy wiring and components, it will affect the sound.
Of course the pre amp and signal path prior to the converters is very important.
Not knowing what total signal path differences there were from your rig to the apogee rig, there may have been a combination of things that simply were better.
Having said all of THAT, I run a double Delta 1010 rig synched with a Lucid GenX master clock. I recently upgraded to a Lucid D/A for playback / monitoring (all clocking from the same source). The difference was VERY apparent in the clarity of my allready recorded tracks.The Lucid is quieter and clearer You can A/B through the Deltas and the Lucids and the same tracks sound very different.
That tells me the Deltas input conversion is better than the playback section, I simply was not hearing the quality of what I DID record. I wish I could record the same thing through 2 different converters and listen to side by sides for comparison.
I am going to purchase at least 2 channels of Lucid / Apogee type quality and see what the difference really is on my existing set up.
That probably does not help much but it is a jumping off place.
Tom
Tom Menikos
T-Mix Studios
Mansfield Texas
WWW.tmixstudio.com
Old 07-04-2006
Soundmind??'s Avatar
Soundmind?? Soundmind?? is offline
Dedicated Member
Soundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond repute
The Apogees are definitely better, but that was only part of a very strong signal path at the studio. Better monitors, preamps, converters, so the "big difference" may not be there if you take the Apogee home and put it in your rack. It will definitely improve things, but it may not be as impressive as it was at the studio. The 1010 is a fine converter for home studios that don't have the multi thousand dollar budgets.
Old 07-04-2006
MadMax MadMax is offline
Dedicated Member
MadMax has a reputation beyond reputeMadMax has a reputation beyond reputeMadMax has a reputation beyond reputeMadMax has a reputation beyond reputeMadMax has a reputation beyond reputeMadMax has a reputation beyond reputeMadMax has a reputation beyond reputeMadMax has a reputation beyond reputeMadMax has a reputation beyond reputeMadMax has a reputation beyond reputeMadMax has a reputation beyond repute
Tom
Isn't better D/A conversion just icing on the cake? I mean, it's just for monitoring purposes unless you're going outside the box for external processing.
Superhuman said he went to a pro studio and the difference was mind blowing. I'll bet there were a lot more factors involved than just the D/A converters.
How about mics, preamps, A/D converters, Clocks, Analog mixing or all ITB? Monitors, room acoustics, yada yada yada.
I had a Delta 1010 and it sounded good until I got a Fireface and treated my room and some new mics and pre's. It's a lot of money, and each little piece doesn't make a huge difference, but the difference now is quite noticeable.
BUT- over the past 6 mos. I've spent about $12,000! (no wonder I'm not married!).
Old 07-04-2006
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
I saw "the chip" mentioned in there - While it's relatively important, it's only a factor in the puzzle. The rest of the circuitry is just a whisker on the important side also...
But clocking isn't a joke either - A good clock can make a fairly dramatic difference in an otherwise "okay" sounding set of converters...
And I wouldn't call it "icing on the cake" - More like "weakest link in the chain" if that's the issue. Especially on the input side and if there's any outboard loops going on.
True, it isn't going to have the impact of switching mic preamps and yada, yada... But I've come to be a very "top of the chain down" type person - Monitoring first. Conversion second. Everything else later.
If you tackle your monitoring (including the room, of course) and your conversion first, you can make *accurate judgments* on everything else.
Without that, you're trying to assess clarity and color through foggy glass.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 07-04-2006
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
With most converter chips, the clock is part of the chip. While chips usually can take an external clock, it is probably better to get a good converter rather than a crap converter and a good clock. The crap converter will probably still have poorer dynamic range irrespective of the clock. The chip is essentially a limiting factor--it isn't possible for the converter to perform better than the chip's specs, but if the rest of the circuit is screwy, then it can get worse . . .
Old 07-04-2006
mattyc mattyc is offline
Newbie
mattyc is on a distinguished road
hey buds,
semi-related question: i am using an emu interface right into my laptop and mixin in cubase but i would like to start outbourd mixing and signal processing (for fun as well as experience.) i have heard people praise the emu converters but i wanted to know if they were good enough to justify an extra d/a to a/d conversion in the chain? thanks for the wisdom.
-matt
Old 07-04-2006
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
The Apogee is better, but then probably was the rest of the signal path at the studio, as has been mentioned. Included in that would be playback. Did you take any tracks you recorded on your Delta and play them back through the studios monitors? They would probably sound better too.
But really the bottom line is always that "you get what you pay for".
You could get similar quality conversion in your home studio using the Apogee Rosetta 200, UA 2192, Mytek or Lavry converters, for example. But cost is a factor.
http://www.misterpotts.com
Old 07-05-2006
chessrock's Avatar
chessrock chessrock is offline
Banned
chessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond repute
I just got done driving a professional race car that used Good Year tires.
I was so impressed with how fast those tires were. Should I put Goodyear tires on my piece of shit in the driveway? Will it go as fast as the race car if I do?
Old 07-05-2006
studiomaster's Avatar
studiomaster studiomaster is offline
MachWave
studiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond repute
Nice analogy, chess.
Old 07-06-2006
gcapel's Avatar
gcapel gcapel is offline
boom box recordings
gcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond repute
No one has mention RME yet. I have been curious about these converters. They look to be a mid price range converter like MOTU.
Could anyone shead a little light on RME? As far as playback and inputs that is. I too use the 1010. When someone said there playback wasn't good, I was thinking Eureka. I have noticed this as well. This makes me feel a lot better about adding a apogee rosetta 200 2 ch. in/out converter to my studio. Use the apogee for playback and single channel instuments, drum overheads and vocal, while using the 1010 for close mic drum tracking.
  #12
Old 07-06-2006
In Tune Audio In Tune Audio is offline
Dedicated Member
In Tune Audio is on a distinguished road
It effects more than that. It will effect the initial quality of signal in when it converts from analog to digital. So even if you mix totally in the box, it will effect every track.
  #13
Old 07-06-2006
Shagaholic
The rest of the gear in my chain is pretty good, I DI with a Mesa Boogie Triaxis through a Mesa poweramp and a Palmer PDI-03 amp sim, straight into the Delta 1010. The only difference with the chain in the studio I went to was the Apogee AD8000 unit but the sound was far superior. The monitors in the studio no doubt had a large roll to play, they were a set of Genelec's as opposed to my own Tannoy Reveals.
I recorded a few riffs at home with the idea of importing them into a studio project but after they were loaded into ProTools and played alongside fresh studio recordings using the same gear (except for the AD converter) the sound was very different. The Delta recordings sounded kind of flat along side the Apogee which was brighter and seemed to have more depth and clarity.
  #14
Old 07-06-2006
1K Silver Member
This was my thought as well.
Tom Menikos
T-Mix Studios
Mansfield Texas
WWW.tmixstudio.com
  #15
Old 07-06-2006
chadsxe chadsxe is offline
Dedicated Member
chadsxe has a reputation beyond reputechadsxe has a reputation beyond reputechadsxe has a reputation beyond reputechadsxe has a reputation beyond reputechadsxe has a reputation beyond reputechadsxe has a reputation beyond reputechadsxe has a reputation beyond reputechadsxe has a reputation beyond reputechadsxe has a reputation beyond reputechadsxe has a reputation beyond reputechadsxe has a reputation beyond repute
Question....
I have a delta 1010. I am looking to get a high end A/D converter that is two channels. Everything points towards the Lavry converters. Now will I be able to set my system up so be needed (DRUMS) I can use both the Lavry and the delta at the same time.
  #16
Old 07-06-2006
mef_1975 mef_1975 is offline
Newbie
mef_1975 is on a distinguished road
Listen to SuperHuman shred!!!
I enjoyed your 2 songs... I laughed when you mentioned the "pre Black" Metallica.
  #17
Old 07-06-2006
NL5's Avatar
NL5 NL5 is offline
Unpossible!
NL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond repute
You answered your own question.
While everything in the chain is important, in this case, it is ONLY the converters that were different when comparing the two tracks...........
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F.
  #18
Old 07-06-2006
Robert D Robert D is offline
Close to the Edge
Robert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond repute
I'm confused, I thought they were home recorded tracks vs studio recorded tracks?
Regards,
RD
http://www.myspace.com/twentysevenmoons
  #19
Old 07-06-2006
fraserhutch's Avatar
fraserhutch fraserhutch is offline
Flypaper for freaks
fraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond repute
Yes, but he said he use0d the same chain in the studio except for the convertor. So the only differences would be the convertors, the room, and the engineer.
The fact that no one understands you doesn't mean you're an artist...
  #20
Old 07-06-2006
NL5's Avatar
NL5 NL5 is offline
Unpossible!
It's DI, so the room is out of the equation as well - pretty much the engineer too.
They were played back at the same studio with the same gear as well.....
  #21
Old 07-06-2006
gcapel's Avatar
boom box recordings
BTW guys, don't listen to the guys in Guitar Center or Sam Ash when they say there isn't a difference between converters on an apogee vs the brand (presonus, etc..) that they have in stock. They are just trying to sale you something right then and there.
  #22
Old 07-06-2006
Flypaper for freaks
uhhhh, hellooooooooo......... if you take the advice of anyone who works at GC, you deserve what you get
  #23
Old 07-07-2006
boulty boulty is offline
Newbie
boulty is on a distinguished road
Was the DI going into a high quality pre aswell though? that would have affect the sound aswell.
Also, regarding that goodyear tyre analogy, I think it's incorrect as I would consider monitoring and converters as the engine not the tyres.
  #24
Old 07-07-2006
chessrock's Avatar
Banned
I'm sorry, but the only way a valid comparison could have been made was if you were to lug your Delta 1010 in to the studio with you and compare it head-to-head with all other conditions being equal.
I'm not saying the Apogee isn't better. It very well might be worlds better ... but to think that you've somehow made a valid comparison isolating the conversion as the only variable is pretty naive. Better monitoring will help you make much more valid decisions when tweaking the tone knobs. Simply playing on a different day will have at least some effect.
I realize this is a board full of musicians and all ... and musicians aren't the most scientific breed to say the least. That said, I think there is a lot that some people around here could learn about how to conduct a valid comparison.
  #25
Old 07-07-2006
BRIEFCASEMANX's Avatar
BRIEFCASEMANX BRIEFCASEMANX is offline
Winner chicken dinner!
BRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond repute
I would have stopped your post at "don't listen to the guys in Guitar Center or Sam Ash."
Be true, gentle warrior. Stay with me through the night, my fine stallion, you incredible and powerful beast.
Wild Hogan Recording
A/D Converters Nandoram Digital Recording & Computers 8 05-15-2005 20:21
a/d converters offpiste Newbies 4 01-24-2003 17:00
will better A/D converters "improve" the sound of my 16-bit recorder? Cratinus Other Equipment and Reviews 3 09-04-2002 03:03
Word clock and A/D converters maddrummer Digital Recording & Computers 0 03-10-2002 20:17
A dumb question about A/D converters geekgurl The Rack 6 02-28-2002 14:13
