allen & heath v's DMP3 pre
G'day,
just wondering for drum OH"S would a DMP3 be a better mic pre, than the pre's on my A&H mixwiz? also as I have never used any outboard gear before whats the best way to connect the pre? Inserts? I am running sonar 5 thru delta 1010> WZ 16:2DX cheers, ![]() |
i mean try it that way with the A&H before spending more $ on something which may not really need. |
There is no audible difference between the two. Save your money. The best way to hook up is mic>A&H channel>direct out>Delta 1010. Unless you mod the A&H circuitry, you'll have a post fader send to the Delta 1010. This can be good or bad, but you'll probably find it useful. Think of your A&H as a bunch of channel strips. You've got tone controls, input level & fader control as well as an insert.
You can use the aux sends for monitoring or you can use an aux send to your Delta and use the main outs for monitoring. It's really veratile. FWIW- I just built 4 SCA A12(API Clone) & 2 N72(Neve Clone) preamps and the jury's still out on how much better they are than my MixWiz. My MixWiz 16:2 cost me $900 for 16 pre's and all of the mixing and routing capabilities. 6 SCA preamps cost me $2300... I think the SCA's have a certain something, but not $2300 worth for sure. |
MadMaX: You should maybe look into building a "Green Pre amp" as they are only about $75 a Channel to build and have a sound that Rivals some Pre"s in the $1000 per channel Range....They are very Clear and Clean all through the Frequency Range (20hz to 40khz) and do not tend to color the sound at all....
I can not confim this as Mine aren"t quite finnished yet but every one I have talked to who has built them Raves about them and I have read several reviews were they bested Neves and even the most expensive Foscurite Pre"s and at $75 per channel you can"t go wrong...... so if you are into the DIY thing and want some Good Pre"s at a Price that rivals the cheapest pre"s with a quality that rivals some of the best pre"s then it might be something worth looking in to..... Cheers
M-Audio Delta 44 + Delta 1010LT 5 Piece Drum Kit w6 Cymbals Custom Made Bass Guitar Custom Made Les Paul Guitar Mackie Traction Studio 2.1 P-4 PC w 512mb DDR 80gb HD Sell you used Equipment Here: http://www.proaux.com/phpprobid/index.php |
The advantage to MadMax's way is it lets you ride the faders and use the internal board eq. You have to decide which is more useful for the way you work. |
I built the highly touted SCA's and I'm saying that many people, pro's included, say they are high end pre's. But as of yet, I haven't heard enough of a difference to justify the $$$. Except for a little "character", I can't hear much of a difference. |
This is just a test |
Are you sure someone didn't already do a mod? Mine are pre-fader. Right out of the box. So are most other manufacturers. |
Si, unless someone modded it before you received it, they'll be pre-fader. Doing the modifications is a pain, and requires some care, but the layout of the board makes it a breeze in the scheme of things. Once you get it open, everything is there. I can barely read schematics, and I managed to find the correct jumpers (after a bit of trial and error on channel 1). Kinda wish I bought a newer model that didn't require soldering/desoldering, but the price was fantastic ($700 for a factory second). The routing options are so straight-forward as-is, but to be able to customize them... I never thought twice about the purchase. Finding a desk to fit it on, that's a separate story.
The Jungle... My diggs. |
BTW- my monitoring chain is RME Fireface A/D>Sonar 5PE> RME Fireface D/A>JBL LSR 28P's. My room may be less than perfect in the low end, but I have installed floor to ceiling bass traps in all 4 corners and some HF damping on the walls behind the monitors and the side walls as well as some hanging panels from the ceiling to reduce LF & flutter. Littledog and Heroic- Sorry about my bad. I meant the direct outs, not the inserts. |
#12
Did you get the N72s up and dialed in? Last I heard you just had the A12s up. Anyway, I think for a lot of people coming from decent mid quality pres, there's a period of buyers remorse with expensive pre purchases, followed by the acceptance that it's a game of inches, and that the inches are worth it and add up in the long run. I seem to see people often fall into one of two camps after getting thier new pres..... they either gush about it like they've found the holy grail, and anything less is now junk, or they are a little dissapointed at the modest gain for the big cash outlay. I expect the latter group is a little more honest and objective. I guess there's a third group, the ones who have calibrated thier expectations through experience, and appreciate the incremental gain for what it is. Anyway, I hope the SCAs grow on you as you complete projects with them. |
#13
#14
The N72's were working all along. It was just a case of operator misinformation. The trim controls work differently than on the A12's.
On the A12's it's a true trim ctl. But on the N72's it's an output gain control, so turning it all the way down will allow no output. I'm still in the listening phase of these new pre's. Who knows, I just might get used to hearing them and then realise that everything else sux in comparison. |
#15
The real test is the layering gel a good preamp provides meaning multiple tracks will have a focus and cohesion whereas lower end preamps leave you fighting EQ or plugins to make thinks come together.
| Old allen and heath mixer | Be Loveless | Other Equipment and Reviews | 4 | 06-03-2004 13:29 |
| Allen & Heath preamps | Angusdevil | The Rack | 4 | 04-27-2004 20:27 |
| Allen & Heath....or something else? | sjaguar13 | Other Equipment and Reviews | 10 | 08-22-2003 12:40 |
| Stated Testing out the DMP3 | Rev E | The Rack | 20 | 06-21-2003 18:47 |
| FS yorkville 200B, ibanez bass, allen and heath 14-4-2...... | Cave Dweller | Free Ads for Music / Recording Equipment | 1 | 03-20-2002 00:24 |
