DBX 163x, Why so noisy?
I've had mine a couple years and mostly use it on Kick and when I want to plug in a bass real qwick. I knew going in that they were supposedly not the quietest units but mine has a white noise hiss "Shhhhhhhhhh" that is pretty damn loud. Are they all like that? All my tracks are quiet except the ones I record w/ the 163x. When everythings going you can't hear it but when things quiet down the 163 really stands out. Sure I can cut up that track when possible but sometimes it's not.
So I know, use it when I can... but I'm just wondering if mine is a little noisier than most? Thanks, B. |
Tell us some more how you're using it. And your signal chain.
It shouldn't be *that* noisy. |
Well, either Mic (D6,57,ect...) - Mic Cable (Blue Kiwi) - 163x XLR in - Sytek Pre - out to Layla24. Or if I use the Direct input for some quick Bass guitar same thing...
Actually, maybe that's my problem... I should probably be going into the Sytek pre first and then to the 163x. That's how I run my channels w/ RNC comps. Would going into the 163x 1st possibly cause the "Shhhhhhh" noise? I can't remember why I did it like that , it was a few years ago... but I must have had a reason. Thanks for the help, B. |
Mic pre first..then compressor....always!
Ray |
Let us know if correcing the order sounds better.
I have a feeling it's goig to be night and day. Sucks though, all the tracks you recorded that way are flawed. |
Hey guys, sorry for the momentary laps of reason... I went out of town and forgot where I was at.
So I did/do have everything hooked up right. I think I was just searching for an answer... & I too wondered how/why I could have hooked it up wrong. (I had been on too much Vicodin & Oxycotin is what I was thinking) (Prescribed OF Course) So here's what's happening... I use Cubase SX the Inputs start at -oo w/ a faint signal @ -85 and a decent signal @ -10 to -1 & if it goes to +1 or up it would be clipping. In Cubase SX when my Sytek is Muted all my channells read -oo (totally silent) except the DBX163. It reads -60 w/ the slider far left -50 slider in the middle and -44 far right. I will only use it at about 1/4 because after that the Shhhhhhhh-white noise is just too loud. BUT, when I plug into the Hi-Z Input w/ my Bass the white noise cuts in 1/2 and... It reads -85 w/ the slider far left -78 slider in the middle and -73 far right. I think this Noise is what it's known for and can be livable. Any suggestions? Could this be some type of Ground Loop problem or Balanced/Unbalanced situation? I have No other Ground problems and the DBX163 is plugged into a Furman Power strip. I am using TRS cables between my Sytek and RNCs which drop the input -6db (another thing on my list to change). But the DBX163 to my Layla24 is a plain 1/4". If there's more I can explain just let me know. Thanks, B. |
| DBX 118/119 & 163x | studiodrum | The Rack | 5 | 06-08-2009 12:18 |
| manual for a DBX 163x 1/2 rack compressor/limiter | CDT-sHaG | The Rack | 13 | 01-26-2005 13:51 |
| FS: (2) DBX 163x , Digital Delay | ecs113 | Free Ads for Music / Recording Equipment | 4 | 11-29-2004 12:25 |
| DBX 163x, 263x De-esser, and 563x Silencer | studiodrum | Newbies | 1 | 08-01-2004 13:46 |
| Dbx 163x ??? | cjacek | The Rack | 10 | 10-04-2003 22:29 |
