Go Back   Home Recording > User Forums by Brand > Alesis Forum
Reply    Audiofanzine Alesis Alesis News Alesis Medias Alesis Tests Alesis Articles Alesis User Reviews Alesis Classifieds Ads
Old 06-26-2006
Billyo488 Billyo488 is offline
Junior Member
Billyo488 is infamous around these partsBillyo488 is infamous around these partsBillyo488 is infamous around these partsBillyo488 is infamous around these partsBillyo488 is infamous around these partsBillyo488 is infamous around these partsBillyo488 is infamous around these partsBillyo488 is infamous around these partsBillyo488 is infamous around these partsBillyo488 is infamous around these partsBillyo488 is infamous around these parts
Mixer Problem #2
Ok i have a 16 firewire Multimix made by Alesis.
Stats- There are 8 Mic Ports and 8 Line ins for guitars ok.
-Now the first 6 are microphones for my drums.
-the 7th is my vocals mic.
-the 8th i use for recording the guitarist, obviously through the line in.
PROBLEM- I need to record my bassist. And i wana add it into the same song.
- I wana let my bassist listen to the existing song then play/record to it but
all my lines are filled..
- Can i just take out the guitar line in and put the bass guitar line in or what?
Can Anyone Help
thx
Old 06-26-2006
c0r1n's Avatar
c0r1n c0r1n is offline
Junior Member
c0r1n has a reputation beyond reputec0r1n has a reputation beyond reputec0r1n has a reputation beyond reputec0r1n has a reputation beyond reputec0r1n has a reputation beyond reputec0r1n has a reputation beyond reputec0r1n has a reputation beyond reputec0r1n has a reputation beyond reputec0r1n has a reputation beyond reputec0r1n has a reputation beyond reputec0r1n has a reputation beyond repute
Are you trying to record everything at once?
I have a similar setup, but got around the input limit by putting the guitars into the stereo inputs: (9/10), (11/12), etc. I plugged the bass into my available line in so I could utilize the gain knob (bass was straight into the board). If you are using a Pod or other device for the guitars and don't need the gain, the stereo inputs work nicely. Just set the level of the guitar on the external box. You actually have more than 16 inputs on the thing, if you can utilize the stereo inputs as I've described.
Of course, if you are playing everything, unplug the guitar, lay down the bass, and plug the guitar back in!
Old 06-26-2006
Junior Member
Thanks!!
I didnt kno i could use the 9/10ths line
I dont have an external box thought but there is a line of EQ, aux, post, balance, ect. below the lines so i dont think i may need an external box.
also another question if can be answered.
- How do i add effects from my built in effects?
You know, Hall, Room, Plate, Chorus, Plange, Delay, Pitch.
Im not Really sure i have the right idea with the effects but,
How do i use them and what do they do?
Old 06-26-2006
c0r1n's Avatar
Junior Member
it's in there!
Check out your manual, starting on page 21. It tells you about the effects and how to use them.
Old 06-26-2006
c0r1n's Avatar
Junior Member
also...
There is a great "making the most of your mixer" section in this yamaha manual that explains a lot of basic concepts. you might find it helpful.
http://www2.yamaha.co.jp/manual/pdf/.../MG16_6FXE.pdf
Recording via mixer into soundcard Brendon Bussy Recording Techniques 4 06-17-2006 08:26
Problem with my UB802 mixer russtafari Mixing / Mastering 2 10-28-2005 17:32
Problem hooking my computers up to my mixer xdavidx Digital Recording & Computers 4 05-17-2004 14:12
mackie mixer problem; noise no-sleep Mixing / Mastering 6 12-17-2003 21:23
Digital Mixer (Yamaha O2R) or a good analog mixer with a controller? pisces7378 Digital Recording & Computers 6 10-31-2002 14:54
