Old 06-25-2006
cokesodanotdrug cokesodanotdrug is offline
Newbie
cokesodanotdrug is on a distinguished road
my recordings don't have depth!
Alright so recently I've been trying to record music, I've used my computer (WinXP, soundcard: creative Sound Blaster audigy 2 ZS) and I've used a 4 track (Tascam portastudio 03 MKII) and I've noticed that with both of them, they don't have that deep music feel, it sounds like they're merely surface noises or something. Is there anyway to change this? Using the four track I've tried setting up two mic imputs to give it more of a stereo sound, but it doesn't really work too well, I moved from a large room to a small room. The large room is 4 times as big as the small it's shaped rectangularly with two alcoves, one is meant to be a closet, the other is just an alcove. The small is about 9'X10' rectangular, no funny shapes.
Is there any way to give the recordings more depth? Make them sound more like music rather than surface noises? for examples go to http://www.redrevolution.net there's a flash player on top, wait for that to load and those are the recordings with the computer. I have no idea how to get the recordings from the 4 track recorder onto the computer without going through the computer which would inevitably make the 4 track sound even less desirable than it already is.
Also, the mics Used are, with the computer recordings usually a computer mic *I have tried using the next mentioned mics with a 1/4 to 1/6 *I think* converter* a Speco MHL-1, and an ElectroVoice N/D 757B.
Old 06-25-2006
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
You are recording in mono.....Stop that.
You need to record each instrument with it's own mic(s) and pan them across the stereo field.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 06-25-2006
Newbie
haha I know but even when I try with the stereo stuff (I think?) with the four track it doesn't have that depth that most recordings *even local bands* seem to have.
How should I go about recording to get the stereo effect then? I'll guess I need some sort of mixer and a couple decent instrument mics rather than the ones I mentioned?
Old 06-25-2006
OhSh1rt's Avatar
OhSh1rt OhSh1rt is offline
Who needs a 57 anyway?
OhSh1rt has a reputation beyond reputeOhSh1rt has a reputation beyond reputeOhSh1rt has a reputation beyond reputeOhSh1rt has a reputation beyond reputeOhSh1rt has a reputation beyond reputeOhSh1rt has a reputation beyond reputeOhSh1rt has a reputation beyond reputeOhSh1rt has a reputation beyond reputeOhSh1rt has a reputation beyond reputeOhSh1rt has a reputation beyond reputeOhSh1rt has a reputation beyond repute
signed.
-jeffrey
asswipe - it's your kind that makes me despair for the human race.
Love or hate me, it's all the same
Old 06-25-2006
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
I've noticed a tendency (besides recording at levels that are WAY too hot, which can also easily make a mix sound "small") of close mic'ing every damn thing.
You want "space" and openness" in your recordings? Put some between the source and the mic first.
Not implying that's the problem here, but it could be part of it.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 06-25-2006
Farview's Avatar
If you have to record the entire band at the same time, you will need more mics.
one on the bass, one on the guitar, 3 on the drums, one for each vocal.
At the very least, if you can find two of the same mics, you could put one in front of the bass amp, pointing towards the drums, and the other in front of the guitar amp facing the drums. (about 3 feet away from the amps, with the bass amp on one side of the drums and the guitar amp on the other)
You also need to watch your levels, that recording is really distorted, that doesn't help.
You might want to tune the instruments as well.
Jay Walsh
Old 06-25-2006
Newbie
I'd have to say space between us and the mic is not a big issue, we've got the mic on the other end of the room from us when we record. I just figured I'd try a smaller space to see if maybe that would help contain the noise and get a better sound, but it didn't work.
Old 06-25-2006
Farview's Avatar
You will never get a sense of space or depth with just one mic.
Jay Walsh
Old 06-25-2006
Newbie
When I was in the smaller room I was using the 4 track which has two inputs per track, meaning two mics at the same time.
Old 06-25-2006
Farview's Avatar
Did you record them to two different tracks and pan them?
Jay Walsh
Old 06-25-2006
Newbie
I don't think so, should I have one input go to track1 and the other input go to track two then play both of them and have one play to the left and the other to the right headphone?
  #12
Old 06-25-2006
Farview's Avatar
Yes. If you have 100 mics and they are all panned to the same place, you still have mono.
Jay Walsh
  #13
Old 06-26-2006
Newbie
alright, I tried that out, and it worked, but now I have no idea how to get it to the computer, should I have it direct line from the 4 track player to the computer and play all the tracks at the same time with the left right knobs back and forth? I tried doing each track individually but it didn't work very well.
Also, I think I'm going to pick up some mics, what kind should I get? I don't know too much about mics either.
Charging for recordings bmcclure Mixing / Mastering 26 04-16-2004 17:08
mixing YamPSr500 w/ old recordings?? tcronk Keyboards and Sound Modules 0 01-14-2004 14:21
GT Pro Question - Audio Bit Depth ?? Bulls Hit Cakewalk / Sonar Forum 12 10-01-2003 08:53
Need help... Recordings don't sound so good... timandjes Mixing / Mastering 4 04-09-2002 20:04
Pro Question: Sjoko, Shailat, Skippy, Track Rat, any others... - re: guitar depth Blue Bear Sound Recording Techniques 82 12-14-2001 18:05
